need help to install ZM 1.26.5 on ubuntu 13.10 64 bits
samquad
Post by samquad »
I want to install ZM 1.26.5 on ubuntu 13.10 64 bit
I followed the wiki the easy way 3 step:
http://www.zoneminder.com/wiki/index.ph ... 04_Desktop
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
http://www.zoneminder.com/wiki/index.ph ... on_changes
Install PPA Repository for Zoneminder 1.26.5-1 make error: pakages not found.
Fix a minor omission in teh zm.conf file nano /etc/zm/zm.conf wiki said :
At the end of the file add:
ZM_VERSION=1.26.5
do I need to change the line ZM_VERSION=1.25.0 already present in the file, or I leave the line and I add ZM_VERSION=1.26.5 at the end of file?
for the moment when I run zoneminder is version 1.25 and my camera on my pci card geovision GV800 does not work (the source is always red).
Log file zm:
2014-02-07 06:37:54.077850 zmdc 2303 ERR 'zmc -d /dev/video0' exited abnormally, exit status 255 zmdc.pl
2014-02-07 06:37:54.076087 zmc_dvideo0 3953 FAT Failed to set video format: Invalid argument zm_local_camera.cpp 410
2014-02-07 06:37:54.075630 zmc_dvideo0 3953 INF Starting Capture zmc.cpp 191
2014-02-07 06:37:54.055520 zmdc 3953 INF 'zmc -d /dev/video0' started at 14/02/07 07:37:54 zmdc.pl
2014-02-07 06:37:54.055490 zmdc 2303 INF 'zmc -d /dev/video0' starting at 14/02/07 07:37:54, pid = 3953 zmdc.pl
2014-02-07 06:37:54.052710 zmdc 2303 INF Starting pending process, zmc -d /dev/video0 zmdc.pl
my cameras work well with vlc on ubuntu 13.10.
can you help me to run zoneminder 1.26.5 on ubuntu 13.10?
thank you
Samquad
linuxsense
Re: need help to install ZM 1.26.5 on ubuntu 13.10 64 bits
Post by linuxsense »
Change ZM_VERSION to the current version, you only want it declared once.
What are your settings for the camera? It looks like its probably just not configured properly.
samquad
Post by samquad »
ok.
I just reinstalled ubuntu 12.04 LTS 64-bit with zm 1.26.4 and it works
My card geovision GV800 is recognized is recognized by adding this line on file /etc/modprobe.d/gv800.conf
options bttv card=157,158,158,158
my 12 camera work individually with VLC or ZM:
camera 1 /dev/video0 (0)
camera 2 /dev/video1 (0)
camera 3 /dev/video2 (0)
camera 4 /dev/video3 (0)
camera 5 /dev/video0 (1)
camera 6 /dev/video1 (1)
camera 7 /dev/video2 (1)
camera 8 /dev/video3 (1)
camera 9 /dev/video0 2)
camera 10 /dev/video1 (2)
camera 11 /dev/video2 (2)
camera 12 /dev/video3 (2)
ZM wrok well with 4 cameras only:
or
camera 2 /dev/video1 (1)
if I add 2 cameras from the same Device Path (/dev/video0 or /dev/video1 or /dev/video2 or /dev/video3 ) that I can see only one device channel of this Device Path
I have a problem Device Path multiplexing
Please help me
Samquad
axelm
Post by axelm »
samquad wrote:I want to install ZM 1.26.5 on ubuntu 13.10 64 bit
Samquad
That PPA does not include a package for 13.10. You need to modify the source so it points to the "devel" package.
edit /etc/apt/sources.list.d/iconnor-zoneminder-saucy.list
Mine says:
deb http://ppa.launchpad.net/iconnor/zoneminder/ubuntu devel main
deb-src http://ppa.launchpad.net/iconnor/zoneminder/ubuntu devel main
Then, supposing you already have the zoneminder package installed, from root or sudo
apt-get update
apt-get upgrade
That should upgrade from 1.25.0 to 1.26.5.
Then you have to configure apache2 conf files appropriately, enable cgi mod, and set the default timezone in php.ini.
That's what I remember right now off the top of my head. Sorry but I did not take any notes while doing it. It was a pain in the ...
axelm
Post by axelm »
samquad wrote:ok.
Please help me
Samquad
I had a similar problem with a GV650 card that had 4 cameras on the same BT878a chip. I trashed this crappy card and got a cheap Kodicom 4400R which has a BT878a chip for each camera.
So anyways, for multiplexed cameras on a single BT878a, I remember having to change CAPTURES_PER_FRAME to a higher value (start with 2) so the feed stabilizes after selecting the desired input.
Careful with CAPTURES_PER_FRAME because it acts as an fps divisor. For example, if your card can capture 24 fps and you set CAPTURES_PER_FRAME to 2, you will be getting max 12 fps. That means that if you have 4 cameras your fps will be 3 (ugly).
samquad
Post by samquad »
thank you Axelm but I did not understand everything about /option/config/CAPTURES_PER_FRAME
Here is my configuration that works moderately but I do not have a lot of fps per camera:
/option/config/V4L_MULTI_BUFFER enabled
/option/config/CAPTURES_PER_FRAME=5 --> which value for 9 camera?
For each camera on config:
Maximum FPS=5 -->do I have to delete the value in each camera?
yet all cameras work indivigualy with some little bug multiplexing.
also, when I click montage: missing 3 videos that do not appear and screens are always placed one above the other even if I enlarged the window???
Samquad
linuxsense
How much RAM in that box? Have you raised the shared mem settings? On most systems you will want:
kernel.shmall = 134217728
kernel.shmmax = 134217728
I have a box with a ton of RAM so I went huge on mine, works great.
kernel.shmall = 805306368
kernel.shmmax = 805306368
Put that at the end of /etc/sysctrl.conf and reboot. You can get the same results without a reboot but I prefer taking the extra step when troubleshooting.
samquad
Post by samquad »
My PC has 4 GB of RAM
the file /etc/sysctrl.conf does not exist on my PC
with 4 GB of RAM what value should I enter
kernel.shmall = ?
kernel.shmmax = ?
Thank you
PacoLM
Post by PacoLM »
I believe the default configuration for 1.25.X and above is to use mmap, not shared memory.
Gurus, correct me if I'm wrong.
Check if your computer has some files under /dev/shm/ , if so, then you are using mmap, not shared memory, then you do not need to edit anything in /etc/sysctl.conf.
Hope it helps,
PacoLM
samquad
Post by samquad »
I have many file on /dev/shm : Pulse-shm-xxxxx and zm.mmap.x
in /option/config/CAPTURES_PER_FRAME : what is the optimal value for 9 camera with GV800 card ?
For each camera config in Maximum FPS: What value should I enter?
Thank you
Samquad
