Page 1 of 1
Max Storage Usage Setting
Posted: Mon Oct 14, 2013 4:13 pm
by kbocek
After upgrading to 1.26.3 I can no longer find the "Use Max Storage Percentage" (or whatever it was called) setting. I set this in 1.24.2 to get ZM to flush out old events and keep my storage usage to about 98% or so.
Can anyone tell me where it's located now?
Re: Max Storage Usage Setting
Posted: Mon Oct 14, 2013 8:29 pm
by chippy99
Click on the filters button on bottom of main screen and then select purgewhenfull filter
Posted: Mon Oct 14, 2013 10:16 pm
by kbocek
There it is. Thank you. Looks like the setting survived the upgrade. I had kept the database so I'm sure it's stored there.
The filter has an asterisk next to it. What does that mean?
Posted: Tue Oct 15, 2013 4:10 am
by whatboy
Means it is running in the background...
Posted: Tue Oct 15, 2013 3:49 pm
by kbocek
Thank you. That makes sense.
