ffmpeg can´t handle udp rstp streams
Edit: After hours of research, i found out, that its an old bug (for several years now!) from ffmpeg. So we arn´t able to use h264 streams ... But read the rest, then you will see.
Its maybe the same problem with other postings, but i wish to specify my problems, don´t know if they difference...
Setup:
- ubuntu 12.04.03 with zm and avconv, both from ubuntu running in a kvm-vm with 4 cores on a quadcore xeon server System, 2gb ram for vm
- upgrade with iconnor ppa, needed to correct the database path in zm.conf for getting it sucksessful.
- 4 MP Cams (3* Level One wcs-0030 1280*800 with h264 or mpeg , 1 * older axis with only 1280*1024 mpeg)
- watching the zm on a second monitor with firefox, on ie i never get a picture (cambozola plugin is not fine, it fills my harddrive till it´s full)
when i configure all cams with mpeg i get a poor frame rate of 15 Frames. only with h256 i will get till 30 frames (in zm shown 25) My system load is nearly full with maximum framrate and when motion is in the picture (no motion detection enabled) it gets first slower and after a few seconds it runs with ultra fast speed... not really working good.
So i tought i should better use h264. But its amazing to get it work. No dokumentation is here, because all the option for ffmpeg are a secret (for me). Together with other secrets i don´t understand.
My unknown things are all from options Menu:
- why i have no picture when switching from jpeg to mpeg, te browser changes to vlc but no video
- video stream format under picture, what shall we use here??? swf or asf ? Or anything else is better?
- ffmpeg options seems to make no difference! same picture alle the time, no quality changes. i used this settings: http://www.zoneminder.com/wiki/index.php/Ffmpeg
- ffmpeg output format ??? no changing anyway i use h264, mpg, avi, etc
I thing with the correct ffmpeg options it would work fine with h264 streams, correct?
I would be happy for every help, i last so many hours with getting better results.
Setup:
Re: couldn´t get ffmpeg get working for Firefox, got no vide
I also have the same Errors in log like http://www.zoneminder.com/forums/viewto ... 29&t=20733
Every Cam gives me this error when switching to mpeg on option WEB_P_STREAM_METHOD
Sep 20 18:58:33 ZoneMinder web_php[1122]: ERR [socket_sendto( /tmp/zm/zms-334825s.sock ) failed: Connection refused]
Sep 20 18:58:33 ZoneMinder web_php[28052]: ERR [socket_sendto( /tmp/zm/zms-808614s.sock ) failed: Connection refused]
Sep 20 18:58:33 ZoneMinder web_php[1122]: ERR [socket_sendto( /tmp/zm/zms-240295s.sock ) failed: Connection refused]
Sep 20 18:58:39 ZoneMinder web_php[28038]: ERR [socket_sendto( /tmp/zm/zms-922750s.sock ) failed: Connection refused]
Are these files actually there? /tmp/zm/zms-334825s.sock
What are the permissions/ownership like. Can your user that runs Apache access them?
the tmp owner is www_data, but the picture quality is still very poor.
apache user should be the same, how can i proove it ? can you join irc?
Edit: ah i know what gets me a picture under ff, i disabled auto detection of browser capability to force using cambozola. And it does it, but the picte problem is still the same like using firefox nativ
If you want to check web user you can run ps -ef | grep apache . You'll see the zm processes there too.
I presume you are running 1.26.3. 1.26.x certainly better performance, lower load.
Do you _need_ such a high framerate?
yes it 1.26.3.
so thats ok.
10 Fps isnt really much, controlling the frame rate is also very irritating. i set the cams to 10fps, so the web monitor shows this fps also. but inside the options i seemd to be unable to controll it anywhere. I would like to have more fps on 1280*800, because my cams are capable of 25 fps on good light conditions. But this is only for live view. when i record it i thing 10fps are enough. If the system power is enough...
i haven´t recorded anything till now, because i couldn´t get it run without this disturbing picture.
root@ZoneMinder:/home/torsten# ps -ef | grep apache
root 1061 1 0 19:54 ? 00:00:00 /usr/sbin/apache2 -k start
www-data 2178 1061 0 19:56 ? 00:00:01 /usr/sbin/apache2 -k start
www-data 2179 1061 0 19:56 ? 00:00:00 /usr/sbin/apache2 -k start
www-data 2181 1061 0 19:56 ? 00:00:00 /usr/sbin/apache2 -k start
www-data 2275 1061 0 19:56 ? 00:00:00 /usr/sbin/apache2 -k start
www-data 2276 1061 0 19:56 ? 00:00:01 /usr/sbin/apache2 -k start
www-data 8553 1061 0 20:15 ? 00:00:00 /usr/sbin/apache2 -k start
www-data 9705 1061 0 20:18 ? 00:00:00 /usr/sbin/apache2 -k start
www-data 9706 1061 0 20:18 ? 00:00:00 /usr/sbin/apache2 -k start
www-data 11208 1061 0 20:22 ? 00:00:00 /usr/sbin/apache2 -k start
www-data 11209 1061 0 20:22 ? 00:00:00 /usr/sbin/apache2 -k start
root 11560 3213 0 20:23 pts/0 00:00:00 grep --color=auto apache
i have upgraded ffmpeg with ***//launchpad.***/~jon-severinsson/+archive/ffmpeg?field.series_filter=precise that should be the new enough.
But i also don´t understand the controlling of picture tab. so many option, with no explanation wich helps. what should i enter here for a working h264 stream over ffmpeg?
and i also can´t see in htop that ffmpeg is beeing used. Why not?
Is that with ZM stopped? I'd expect to see the ZM processes show up too.
yes this is with a running zm. But it also the same when i stop zm.
root@ZoneMinder:/home/torsten# ps -ef | grep zm
www-data 18079 1 1 20:42 ? 00:00:00 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
www-data 18102 18079 52 20:42 ? 00:00:02 /usr/bin/zmc -m 1
www-data 18106 18079 37 20:42 ? 00:00:01 /usr/bin/zmc -m 2
www-data 18111 18079 45 20:42 ? 00:00:02 /usr/bin/zmc -m 3
www-data 18117 18079 28 20:42 ? 00:00:01 /usr/bin/zmc -m 5
www-data 18123 18079 10 20:42 ? 00:00:00 /usr/bin/perl -wT /usr/bin/zmfilter.pl
www-data 18128 18079 6 20:42 ? 00:00:00 /usr/bin/perl -wT /usr/bin/zmaudit.pl -c
www-data 18133 18079 7 20:42 ? 00:00:00 /usr/bin/perl -wT /usr/bin/zmwatch.pl
root 18169 3213 0 20:42 pts/0 00:00:00 grep --color=auto zm
how can i see wich command is used for ffmpeg? is that with ps also possible ? i can see ist activ, but not more. Its maybe interesting if it uses my parameter from webif.
how crazy is that? i changed path_ffmpeg from /usr/bin/ffmpeg to /usr/bin/ffmpeggg restartet zm, but i still have a video???? i believe my path_ffmpeg isn´t used, therefor i can give ffmpeg options like i want, nothing will change ...
next i noticed is, that if i leave mpeg_live_format empty i get the video with mpeg but i don´t know what is used for showing it.
If i set any option in it like asf or mkv vlc will start in the live web window but showing only a black screen and with this error for 4 cam activ:
Sep 20 21:28:44 ZoneMinder web_php[1473]: ERR [socket_sendto( /tmp/zm/zms-163349s.sock ) failed: Connection refused]
Sep 20 21:28:46 ZoneMinder web_php[20354]: ERR [socket_sendto( /tmp/zm/zms-042643s.sock ) failed: Connection refused]
Sep 20 21:28:47 ZoneMinder web_php[1473]: ERR [socket_sendto( /tmp/zm/zms-739615s.sock ) failed: Connection refused]
Sep 20 21:28:47 ZoneMinder web_php[20354]: ERR [socket_sendto( /tmp/zm/zms-095248s.sock ) failed: Connection refused]
Sep 20 21:28:47 ZoneMinder web_php[1473]: ERR [socket_sendto( /tmp/zm/zms-163349s.sock ) failed: Connection refused]
root@ZoneMinder:/home/torsten# ls -l /tmp/zm/zms-163349s.sock
srwxr-xr-x 1 www-data www-data 0 Sep 20 21:28 /tmp/zm/zms-163349s.sock
hmm, ffmpeg seems to be unable to decode the stream?
root@ZoneMinder:/home/torsten# ffmpeg -i rtsp://192.168.115.202:554/channel1 /home/torsten/test.avi
ffmpeg version 0.10.8-7:0.10.8-1~precise1 Copyright (c) 2000-2013 the FFmpeg developers
built on Sep 5 2013 14:56:20 with gcc 4.6.3
configuration: --arch=amd64 --disable-stripping --enable-pthreads --enable-runtime-cpudetect --extra-version='7:0.10.8-1~precise1' --libdir=/usr/lib/x86_64-linux-gnu --prefix=/usr --enable-bzlib --enable-libdc1394 --enable-libfreetype --enable-frei0r --enable-gnutls --enable-libgsm --enable-libmp3lame --enable-librtmp --enable-libopencv --enable-libopenjpeg --enable-libpulse --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-vaapi --enable-vdpau --enable-libvorbis --enable-libvpx --enable-zlib --enable-gpl --enable-postproc --enable-libcdio --enable-x11grab --enable-libx264 --shlibdir=/usr/lib/x86_64-linux-gnu --enable-shared --disable-static
avcodec configuration: --arch=amd64 --disable-stripping --enable-pthreads --enable-runtime-cpudetect --extra-version='7:0.10.8-1~precise1' --libdir=/usr/lib/x86_64-linux-gnu --prefix=/usr --enable-bzlib --enable-libdc1394 --enable-libfreetype --enable-frei0r --enable-gnutls --enable-libgsm --enable-libmp3lame --enable-librtmp --enable-libopencv --enable-libopenjpeg --enable-libpulse --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-vaapi --enable-vdpau --enable-libvorbis --enable-libvpx --enable-zlib --enable-gpl --enable-postproc --enable-libcdio --enable-x11grab --enable-libx264 --shlibdir=/usr/lib/x86_64-linux-gnu --enable-shared --disable-static --enable-version3 --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-aacenc --enable-libvo-amrwbenc
libavutil 51. 35.100 / 51. 35.100
libavcodec 53. 61.100 / 53. 61.100
libavformat 53. 32.100 / 53. 32.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 61.100 / 2. 61.100
libswscale 2. 1.100 / 2. 1.100
libswresample 0. 6.100 / 0. 6.100
libpostproc 52. 0.100 / 52. 0.100
[h264 @ 0xd0eb80] P sub_mb_type 12 out of range at 36 11
[h264 @ 0xd0eb80] error while decoding MB 36 11
[h264 @ 0xd0eb80] concealing 3133 DC, 3133 AC, 3133 MV errors
[h264 @ 0xd0eb80] out of range intra chroma pred mode at 70 11
[h264 @ 0xd0eb80] error while decoding MB 70 11
[h264 @ 0xd0eb80] concealing 3099 DC, 3099 AC, 3099 MV errors
[h264 @ 0xd0eb80] concealing 3091 DC, 3091 AC, 3091 MV errors
[h264 @ 0xd0eb80] concealing 3086 DC, 3086 AC, 3086 MV errors
[h264 @ 0xd0eb80] concealing 3094 DC, 3094 AC, 3094 MV errors
[rtsp @ 0xd06680] Estimating duration from bitrate, this may be inaccurate
Input #0, rtsp, from 'rtsp://192.168.115.202:554/channel1':
Metadata:
title : Session streamed by stream
comment : 1
Duration: N/A, start: 0.039889, bitrate: N/A
Stream #0:0: Video: h264 (Baseline), yuvj420p, 1280x800, 5 fps, 20 tbr, 90k tbn, 10 tbc
Incompatible pixel format 'yuvj420p' for codec 'mpeg4', auto-selecting format 'yuv420p'
[buffer @ 0xd10460] w:1280 h:800 pixfmt:yuvj420p tb:1/1000000 sar:0/1 sws_param:
[buffersink @ 0xd155e0] auto-inserting filter 'auto-inserted scale 0' between the filter 'src' and the filter 'out'
[scale @ 0xd049a0] w:1280 h:800 fmt:yuvj420p -> w:1280 h:800 fmt:yuv420p flags:0x4
Output #0, avi, to '/home/torsten/test.avi':
Metadata:
INAM : Session streamed by stream
ICMT : 1
ISFT : Lavf53.32.100
Stream #0:0: Video: mpeg4 (FMP4 / 0x34504D46), yuv420p, 1280x800, q=2-31, 200 kb/s, 20 tbn, 20 tbc
Stream mapping:
Stream #0:0 -> #0:0 (h264 -> mpeg4)
Press [q] to stop, [?] for help
[h264 @ 0x1082400] P sub_mb_type 12 out of range at 36 11
[h264 @ 0x1082400] error while decoding MB 36 11
[h264 @ 0x1082400] concealing 3133 DC, 3133 AC, 3133 MV errors
[h264 @ 0x1082a20] out of range intra chroma pred mode at 70 11
[h264 @ 0x1082a20] error while decoding MB 70 11
[h264 @ 0x1082a20] concealing 3099 DC, 3099 AC, 3099 MV errors
[h264 @ 0x1083060] corrupted macroblock 77 11 (total_coeff=-1)
[h264 @ 0x1083060] error while decoding MB 77 11
[h264 @ 0x1083060] concealing 3092 DC, 3092 AC, 3092 MV errors
[h264 @ 0x10836a0] Invalid level prefix
[h264 @ 0x10836a0] error while decoding MB 2 12
[h264 @ 0x10836a0] concealing 3087 DC, 3087 AC, 3087 MV errors
[h264 @ 0x10815c0] concealing 3094 DC, 3094 AC, 3094 MV errors
[h264 @ 0x1082400] concealing 3099 DC, 3099 AC, 3099 MV errors
[mpeg4 @ 0xd0fe40] Error, Invalid timestamp=0, last=0
Video encoding failed
i have found the reason. Short form: ffmpeg has problems with udp stream over rtsp.
https://trac.ffmpeg.***/ticket/285
I found no way to force ffmpeg to connect over tcp, wich would be a soulution.
Maybe someone has an idea, but the problem is old and therefor i will better forget to try it anymore. Spend the hole evening for research.
Re: ffmpeg can´t handle udp rstp streams
problem with fragmented packets... patch from warmcat (url see in messages, as new user i can`t post it) solved this problem...
but it`s so old...
I offer my patch (on current version - 1.26.3) see attached file
but it`s so old...
- master2rtsp.zip
- recive rtsp stream
- (3.71 KiB) Downloaded 247 times
