i've installed 1.26.2 and i have a Panasonic BL-Vt164 via ffmpeg to zoneminder connected.
Settings:
Qellentyp = Ffempeg
Source Path = rtsp://xxxx:xxxxx@192.168.0.141:554/MediaInput/h264/
Target Colorspace= 24-Bit
Resolution= 1280x720
I have no errors with version 1.25.0
I've added two picture. Has anybody a idee?
thx.
FFmpeg Pictureerrors
- Error-Picture
- 027-analyse.jpg (84.24 KiB) Viewed 3457 times
- normal
- 010-capture.jpg (86.11 KiB) Viewed 3457 times
Re: FFmpeg Pictureerrors
For what it's worth, I have the same problem. Same smearing, and generated alarms.
Different camera than yours.
Seems to happen at high bitrates.
I also have the same Problem, but its ffmpeg only. When using extern source with IP Adresse the picture is fine. And its eaqual if its h256 or MPEG stream Form cam.
But for me its not New. Same behavior in 1.25.
It worked nice with 1.25
Any Ideas?
slowing down the FPS is no solution
Any Ideas?
Had that problem too... uninstalled FFMPEG and installed new one!!! fix it... no more problems!!!
Actually wasn't that simple, after installed newest FFMPEG had to rebulid zm, because the errors about FFMPEG libs... and then execute ldconfig...
OLD ffmpeg version... problems...
NEW ffmpeg version, no problems!!!
FFmpeg version SVN-r26402, Copyright (c) 2000-2011 the FFmpeg developers
built on Jun 15 2013 17:28:03 with gcc 4.5.1 20100924 (Red Hat 4.5.1-4)
configuration: --enable-shared --enable-pthreads --enable-gpl --prefix=/usr/local --enable-swscale
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 1 / 0.16. 1
libavcodec 52.108. 0 / 52.108. 0
libavformat 52.93. 0 / 52.93. 0
libavdevice 52. 2. 3 / 52. 2. 3
libavfilter 1.74. 0 / 1.74. 0
libswscale 0.12. 0 / 0.12. 0
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Use -h to get full help or, even better, run 'man ffmpeg'
ffmpeg version N-56254-gb7bd688 Copyright (c) 2000-2013 the FFmpeg developers
built on Sep 28 2013 19:20:33 with gcc 4.5.1 (GCC) 20100924 (Red Hat 4.5.1-4)
libavutil 52. 43.100 / 52. 43.100
libavcodec 55. 31.101 / 55. 31.101
libavformat 55. 16.102 / 55. 16.102
libavdevice 55. 3.100 / 55. 3.100
libavfilter 3. 84.100 / 3. 84.100
libswscale 2. 5.100 / 2. 5.100
libswresample 0. 17.103 / 0. 17.103
libpostproc 52. 3.100 / 52. 3.100
