"Converting filters from PHP to JSON format" failed
redxiii
Post by redxiii » Wed Sep 17, 2014 5:08 pm
upgrading from 1.24 (ubuntu 10.04) to 1.25 (ubuntu 12.04) yields the following errors:
# dpkg --configure zoneminder
Setting up zoneminder (1.25.0-1) ...
Stopping ZoneMinder: DBD::mysql::st execute failed: Table 'zm.Logs' doesn't exist at /usr/share/perl5/ZoneMinder/Logger.pm line 609.
Zoneminder already stopped
Initiating database upgrade to version 1.25.0 from version 1.24.2
Upgrading database to version 1.25.0
Loading config from DB
Saving config to DB
Database successfully upgraded from version 1.24.2.
Database successfully upgraded from version 1.24.3.
  PurgeWhenFull - failed, please check or report. Query is '{"sort_field":"Id","terms":[{"val":0,"attr":"Archived","op":"="},{"cnj":"and","val":95,"attr":"DiskPercent","op":">="}],"limit":5,"sort_asc":1}'
ERROR: Unknown type {. at /usr/bin/zmupdate.pl line 930
Conversion complete
ERROR 1142 (42000) at line 10: CREATE command denied to user 'zmuser'@'localhost' for table 'Logs'
Output:
Command 'mysql -hlocalhost -uzmuser -pzmpass zm < /usr/share/zoneminder/db/zm_update-1.24.4.sql' exited with status: 1
dpkg: error processing zoneminder (--configure):
 subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
 zoneminder
redxiii
Re: "Converting filters from PHP to JSON format" failed
Post by redxiii » Tue Oct 28, 2014 6:31 am
the code below seems to have helped, but i still got these errors:
and
but ZM is running now at least and the PurgeWhenFull filter is still there...
are there more things i need to fix?
$ sudo mysql -uroot -p
Enter password:
Welcome to the MySQL monitor.  Commands end with ; or \g.
Your MySQL connection id is 151
Server version: 5.5.38-0ubuntu0.12.04.1 (Ubuntu)
Copyright (c) 2000, 2014, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql> use zm
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
mysql> show grants for 'zmuser'@'localhost';
| Grants for zmuser@localhost        |
| GRANT USAGE ON *.* TO 'zmuser'@'localhost' IDENTIFIED BY PASSWORD '*X' |
| GRANT SELECT, INSERT, UPDATE, DELETE, ALTER, LOCK TABLES ON `zm`.* TO 'zmuser'@'localhost'                    |
2 rows in set (0.00 sec)
mysql> grant create on * to 'zmuser'@'localhost';
Query OK, 0 rows affected (0.00 sec)
| GRANT SELECT, INSERT, UPDATE, DELETE, CREATE, ALTER, LOCK TABLES ON `zm`.* TO 'zmuser'@'localhost'            |
mysql> exit
Bye
$ sudo apt-get install zoneminder
Reading package lists... Done
Building dependency tree
Reading state information... Done
zoneminder is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 53 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]?
Saving config to DB
Conversion complete
Database successfully upgraded from version 1.24.4.
Database upgrade to version 1.25.0 successful.
Starting ZoneMinder: success
