Modetect never finishes
az10sbum
Post by az10sbum » Mon Oct 28, 2013 7:02 am
I am reposting this question so it can be it's own topic. Hopefully someone has an idea of what I can try.
I am using two Foscam network cameras set to Modetect. When I get a detection on either camera, I will see "New Event" with a duration of 0.00 seconds on the list of events. (I have it setup so my events are normally named after my cameras like "C1_Event_9").
If I stop zoneminder using
systemctl stop zm.service
and then restart it, the task name of the hung event will change to an expected name, and it is clear that the hung event was recording the whole time because the duration will change from 0.00 seconds to something very large. Also, if I change the camera from Modetect to Monitor, the task will complete. It seems like Modetect just doesn't ever stop although the motion detection trigger seems to work fine.
As an example, my wife drove into the carport the other night, and this morning my disk percentages were way up. I stopped zoneminder, restarted it and had a very long Motion event that triggered when she drove in.
What can I check?
Dave Miller
bb99
Re: Modetect never finishes
Post by bb99 » Mon Oct 28, 2013 10:48 am
Sounds like the monitors were inadvertently linked. Delete both monitors and recreate (use a different name) being careful not to mess with the linked monitor section at all.
az10sbum
Post by az10sbum » Tue Oct 29, 2013 12:19 pm
Thanks bb99. This was the problem.
I first tried to unlink the monitors by opening and editing the cameras, but it seems that once they are linked, you can't unlink them. At least the selection wouldn't "un-highlight". I am guessing this is the reason for the specific instructions
(Perhaps this is a bug with the control that could be added to the development list?)
I then deleted the cameras and created them again and the problem was solved.
Thanks again
Dave Miller
mastertheknife
Post by mastertheknife » Tue Oct 29, 2013 6:08 pm
This issue does not need any fixing, it's already fixed in 1.26.x
The code in 1.26.x simply ignores linking a monitor to itself.
Kfir Itzhak.
bb99
Post by bb99 » Tue Oct 29, 2013 10:50 pm
Control left click should remove the link but it's not a sure thing. Deleting and recreating is
Zoy58
Post by Zoy58 » Thu Jan 26, 2017 9:25 am
Just a quick note - if you are using a Mac, to unlink monitors it is Command + click, NOT Control + click
But the good news is - it works :)
Users browsing this forum: No registered users and 6 guests
