Foscam FI8919W Control
MKEbrew
Post by MKEbrew » Tue Oct 15, 2013 8:01 pm
I've tried the Foscam script from the Wiki for the 8908W for this camera, but when I try to control it I receive this error:
Control response was status = undefined
message = /usr/bin/zmcontrol.pl --autostop --command=moveConLeft --id=3=>
Need some direction on this. Even links to past posts might be helpful as I'm not finding info or I'm not searching very well on here.
Thanks!
bb99
Re: Foscam FI8919W Control
Post by bb99 » Wed Oct 16, 2013 2:52 pm
Should get you started in the right direction: http://www.zoneminder.com/wiki/index.php/Foscam
MKEbrew
Post by MKEbrew » Wed Oct 16, 2013 3:06 pm
bb99 wrote:Should get you started in the right direction: http://www.zoneminder.com/wiki/index.php/Foscam
Thanks, but that is exactly what I was referring to when I said wiki. What do I need to tweak?
Black_64
Post by Black_64 » Sat Oct 26, 2013 6:30 pm
I get the same error message when i try to control the Foscam FI8919W.
Is there in the mean time a solution?
When sending the commands from a browser then it works.
Here a example to move the Foscam to preset 1.
h**p://ip_cam/decoder_control.cgi?command=31
MKEbrew
Post by MKEbrew » Mon Oct 28, 2013 12:54 pm
Hi Black,
Looking at the FoscamFI8908W.pm file form the Wiki, command=31 is not even in there. It ends at 25. It shouldn't be too hard to add, but I can't tell how it's supposed to be added.
That said, I can't get any of the other movements to work either.
Black_64
Post by Black_64 » Mon Oct 28, 2013 8:51 pm
I use a newer control file that is more fitting my cam:
# ZoneMinder Foscam FI8918W IP Control Protocol Module, $Date: 2009-11-25 09:20:00 +0000 (Wed, 04 Nov 2009) $, $Revision: 0001 $
# Modified for use with Foscam FI8918W IP Camera by Dave Harris
# Modified Feb 2011 by Howard Durdle (h**p://durdl.es/x) to:
#      fix horizontal panning, add presets and IR on/off
#      use Control Device field to pass username and password
There are the preset's already included.
But i still get the message, so no way to control my cam. :cry:
MKEbrew
Post by MKEbrew » Mon Oct 28, 2013 8:57 pm
Thanks. Now I can switch to that one, but it still doesn't get us anywhere. Someone has to be able to toss out ideas... :(
joako
Post by joako » Tue Oct 29, 2013 3:14 am
Check the .pm file and find the section like:
sub moveConLeft {
LOOK HERE
There will be a line like: my $cmd = "ptzctrl?act=zoomin";
If you access http://ip of camera/ptzctrl?act=zoomin in your web browser what happens? Of course yours will not say "ptzctrl?act=zoomin" but something else.
MKEbrew
Post by MKEbrew » Tue Oct 29, 2013 12:21 pm
joako wrote:Check the .pm file and find the section like:
Well, that works as expected, however when attempting to control from within Zoneminder it does not work.
Thanks for your reply.
MKEbrew
Post by MKEbrew » Tue Oct 29, 2013 1:00 pm
Taking a look at the log directory, web_php.log shows a little more info about the error:
10/29/13 07:53:21.717398 web_php[21938].ERR [/usr/bin/zmcontrol.pl --autostop --command=moveConRight --id=3=>] at /usr/share/zoneminder/includes/functions.php line 2323
Line 2323 is part of this function (line 2323 begins at "Error"):
function ajaxError( $message, $code=HTTP_STATUS_OK )
    Error( $message );
    if ( function_exists( 'ajaxCleanup' ) )
        ajaxCleanup();
    if ( $code == HTTP_STATUS_OK )
        $response = array( 'result'=>'Error', 'message'=>$message );
        header( "Content-type: text/plain" );
        exit( jsonEncode( $response ) );
    header( "HTTP/1.0 $code $message" );
    exit();
Is any of this helpful?
MKEbrew
Post by MKEbrew » Mon Apr 28, 2014 8:18 pm
Ok, I am reviving this thread because I am back at this project and never resolved the control issue for this camera.
The control file is correct -- the commands all check out and work when I plug them into the address bar.
The problem seems to be related to the ajaxError function in functions.php as per the post right above this one.
Using PHP 5.4 - output of php -v:
PHP 5.4.4-14+deb7u2 (cli) (built: Jun  5 2013 07:56:44)
Copyright (c) 1997-2012 The PHP Group
Zend Engine v2.4.0, Copyright (c) 1998-2012 Zend Technologies
Not sure where to go with this next. Is there a way to get more verbose logging? What should I be doing to figure this out?
Thanks.
al_mello
Post by al_mello » Wed Apr 20, 2016 12:25 am
Guys,
Just got Zoneminder installed and am trying to play and learn how to use it (pretty nice application I must say).
I got all my cameras working and recording when movement is detected, was able to link cameras to get another recording when movement in the area is detected, etc. Very interesting.
Now I'm playing with the PTZs and one of my cameras is exactly the FI8919W that I bought hoping it would work with ZM, using the 8918w controls. Unfortunately it doesn't or I'm doing something wrong.
Looking at the forum I found this thread, but last post was years ago, so no hope from this.
Did anyone got the FI8919W PTZ controls to work? If so could share?
Thanks!
MKEbrew
Post by MKEbrew » Wed Apr 20, 2016 12:20 pm
I did not, but I did give up at some point. If you figure it out, I'd love to have it working here.
