1 fps in record
1 fps in record
Hello!
How i can increase a value for record: 1.03 fps?
Screenshot in attachement
- fps.png (23.79 KiB) Viewed 3099 times
Re: 1 fps in record
Post IP camera or capture card model and your monitor settings. Too many variables involved to help you with the above request.
Re: 1 fps in record
I use dlink ip camera dcs 2103. I have already solved the problem - In the camera settings there is an option of fps.
Now i have a 15 fps and that good=)
But i have a new problem. Live video freezes after minute when I watch the zoneminder monitor. And video continues only after refreshing the page
Monitor settings in attachements
- Monitor - Cam1-3.png (17.41 KiB) Viewed 3030 times
- Лазаревское - Монитор - Cam1-2.png (26.07 KiB) Viewed 3030 times
- Лазаревское - Монитор - Cam1.png (23.19 KiB) Viewed 3030 times
Re: 1 fps in record
Try setting this monitor up using FFmpeg as your source type.
Re: 1 fps in record
After i try setting this monitor using FFmpeg as source type, i have somthing like that in monitor stream:
- Лазаревское - Cam1 - Feed.png (69.68 KiB) Viewed 3012 times
Re: 1 fps in record
Monitor configuration:
- Лазаревское - Монитор - Cam1-3.png (19.89 KiB) Viewed 3012 times
- Лазаревское - Монитор - Cam1-2.png (23.29 KiB) Viewed 3012 times
Re: 1 fps in record
Try: rtsp://x.x.x.x/video1.sdp
Re: 1 fps in record
Works only with rstp/unicast protocol =)
Users browsing this forum: No registered users and 5 guests
