Page 1 of 1
Foscam fi9821
Posted: Mon Jul 01, 2013 1:13 am
by cfwilk
Has anyone on the planet gotten this Foscam device to work with ZM 1.25?!
I have used non-HD Foscams no problem - can't get or find anyone who has right settings for Foscam 9821.
PLEASE HELP!
Thanks!
Re: Foscam fi9821
Posted: Fri Jul 05, 2013 9:25 am
by skydreamer
I have it working with no issues, the camera is actually very good with wide viewing angle. The only downside is that you can focus either the centre or the sides of the picture but not both.
You can follow the Wiki for Foscam cameras or do you have any specific issue? How did you set it up?
on the source page:
Protocol http, method simple, host path /cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=, 24 bit colour, 1280x720
Re: Foscam fi9821
Posted: Sat Jul 06, 2013 1:12 pm
by cfwilk
My App Firmware Version is 1.1.1.13, btw - is that yours?
I have tried hundreds of Source Types, Protocols, Methods, Host Names, Host Paths, etc.
In addition, I have a VERY skilled friend at work who makes a living "hacking" Linux and he's played with it for me. He says it seems as if Foscam has the RTSP stream in some kind of "wrapper" so that it's not being interpreted. In fact, we can't even get the RTSP Stream to work in VLC or anywhere.
Are you able to?
I am open for any suggestions - been fighting with this for months.
Thanks for reply.
Re: Foscam fi9821
Posted: Sat Jul 06, 2013 3:15 pm
by skydreamer
Yes, 1.1.1.13 is the latest firmware and I have it installed on the Foscam cameras.
Did you try the settings that I posted in my first reply?
I did not play with the rtsp stream so cannot confirm your findings.
Re: Foscam fi9821
Posted: Sun Jul 07, 2013 2:20 pm
by cfwilk
Yes I did. I tried it with your string, WITH a username, with a password, without a password, etc. No luck.
Re: Foscam fi9821
Posted: Sun Jul 07, 2013 2:49 pm
by skydreamer
I beg your pardon the string is actually longer:
/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=username&pwd=password
substitute username and password for the foscam credentials
If this does not work then try to open the below link in a browser:
http://yourwebcam/cgi-bin/CGIProxy.fcgi ... d=password
Again substitute yourwebcam for either the name or ipaddress of the foscam device.
It MUST open a snapshot from the webcam, if it does not you have some other issue- network or credentials.
Re: Foscam fi9821
Posted: Sun Jul 07, 2013 3:23 pm
by cfwilk
The string still not working in ZM but it DOES give me the correct snapshot in a browser.
Using "mycameraip" for Host Name - pretty sure that's right but I'll try anything.
Thanks for continued replies.
Re: Foscam fi9821
Posted: Sun Jul 07, 2013 9:21 pm
by skydreamer
Cool, just double checking do you have any other camera currently connected to zoneminder that is working?
I want to rule out zm configuration issues.
Other than that your source page of the foscam camera should be set to the values listed above.
What do you get on your camera feed in zoneminder- a black frame or nothing at all?
Re: Foscam fi9821
Posted: Mon Jul 08, 2013 5:10 am
by Flasheart
The shared memory settings may well need tweaking - see the Wiki FAQ and search for "shmall". The number there may need to be bigger than given for megapixel.
And read the logs - /var/log/syslog is where zm mutters constantly (in debian and ubuntu at least)
Re: Foscam fi9821
Posted: Tue Jul 09, 2013 9:51 pm
by cfwilk
Thank you VERY much for replies but it's working!
Source Type: Ffmpeg
Source Path: rtsp://username:password@xxx.xxx.xxx.xxx:80/videoMain
I had tried that string before but never tried the ":80" because I always used the default port of 80.
Thanks again! I think I'm gonna get one or two more now unless someone has a better cam to suggest.
Re: Foscam fi9821
Posted: Tue Jul 09, 2013 9:54 pm
by cfwilk
One more thing now that I have video - can you direct me to a working .pm file for Control? I found several for the VGA model Foscams I used to have - I eventually got one to work perfectly and I accidentally lost it when I wiped my ZM machine. Thanks.
Re: Foscam fi9821
Posted: Thu Aug 28, 2014 3:15 am
by marvel
Don't mean to resurrect an old thread but this seemed the best place for this info.
I had a really rough time getting my FI9821 working with Zoneminder. The final fix was nearly identical to that posted here, I just had to change the rtsp port to 88:
rtsp://username:password@xxx.xxx.xxx.xxx:88/videoMain
Wanted to leave this here in case somebody else has trouble with one of these cameras. Now, I need to figure out how to control the PTZ functions via Zoneminder...
Re: Foscam fi9821
Posted: Thu Aug 28, 2014 7:57 am
by skydreamer
I found these cameras so unreliable i.e. randomly locking up and rebooting for no reason that they had to be replaced after one year in use with similar class cameras TV-IP672P. I would have preferred using Foscam for their wide angle of view but my experience and general feedback from other owners made me to bite the bullet and swap them out. Foscams worked fine for the first three months and the trouble started later. I even tried to replace the original power supplies but no improvement.
Re: Foscam fi9821
Posted: Thu Aug 28, 2014 8:28 pm
by marvel
I'm not incredibly impressed with mine, to tell you the truth. It was twice the physical size I expected, far too large to put discretely in my home so it wound up in the garage. I can't say I've seen it lock up yet, but the firmware is iffy and leaves a lot to be desired. I won't be buying any more of them.
I just installed an Axis M1054 in the spot where the Foscam was going to go. It was 4.5x the price of the Foscam, but you really do get what you pay for. I love it and will probably buy more Axis cameras.
