Streaming Video not working
I have installed zoneminder on ubuntu 12.10 and everything is working apart from streaming videos.
When i click on an event the window opens but the stream does not work.
if i change to stills then i can see all the images with this stream.
when i look in zoneminder log i see the following that it cant find the sock file as below.
Zoneminder Error Log
2013-05-22 20:24:56.538137 web_php 9399 ERR socket_sendto( /zoneminder/sock/zms-099757s.sock ) failed: No such
file or directory /usr/share/zoneminder/includes/functions.php Line 2322
When i look i list this directory at the same time of the error there is a sock file created for a short time as below and is then deleted. I discovered this by doing ls on the directory whilst trying to view a zoneminder triggered event.
Directory listing at the time of error
root@zm-media-pc:/zoneminder/sock#
srwxr-xr-x 1 www-data www-data 0 May 22 06:27 zmdc.sock
srwxr-xr-x 1 www-data www-data 0 May 22 20:24 zms-099757w.sock
the differance is that one has zms-******s.sock as the name whilst the other is zms-******w.sock.
can anyone please help me determine which script is generating these random sock names so that i can get them both the same and i think then that streaming will work
thanks
thanks
Re: Streaming Video not working
Did you ever solve this as I have the same problem on Debian.
Richard
Richard
i still have the same problem and am not able to find out how to get the filenames to be the same for the streaming to work.
I have the same problem on Fedora 19. I will post any results.
George....
George....
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
N4ZPO (ham Radio)
I am also having this problem with Ubuntu 13.04
Still pictures events are ok, I can view them if i click them.
However, i cannot stream and have a similar socket error. - "No Main Content Type" error in the streaming window.
Zoneminder log output:
2013-06-30 16:07:24.262692 web_php 8048 ERR socket_sendto( /tmp/zm/zms-489163s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2323
Any ideas?
** using a D-Link DCS-930L Camera
Any ideas?
I've been working on this all day and am ready to pull my hair out!
lol, and i can't even post a picture of my problem as the site is telling me that "as a new user off-site URLs look spammy"
was able to capture a pic of my headache... and help would be great.
I can see images in the events folder, but there is nothing in the actual images folder.
Using a Dlink DCS-930L camera, and am not able to stream
setting the camera to the monitor setting it goes orange, but on any other setting it goes green.
Could it be an alias problem? From my notes a year ago:
2012-06-27 23:33:16.107014 web_php 3769 ERR socket_sendto( /tmp/zm/zms-907324s.sock ) failed: No such file or directory includes/functions.php 2322
looks like a conflict in http requests
I tried:
and commented out the line starting with Alias
and then:
This stopped the socket_sendto problem but it change the url used to access zoneminder and view monitors.
Berfore:
http://<ip>/zm/
After:
http://<ip>/
I've since done a new install and http://<ip>/zm/ works.
$ sudo service apache2 restart
* Restarting web server apache2 [Wed Jun 27 23:21:34 2012] [warn] The Alias directive in /etc/apache2/sites-enabled/001-zoneminder at line 1 will probably never match because it overlaps an earlier Alias.
... waiting [Wed Jun 27 23:21:35 2012] [warn] The Alias directive in /etc/apache2/sites-enabled/001-zoneminder at line 1 will probably never match because it overlaps an earlier Alias.
I tried:
$ sudo nano /etc/apache2/sites-enabled/000-default
and then:
Berfore:
http://<ip>/zm/
After:
http://<ip>/
try changing the path from /tmp/zm to /tmp restart zm
regards
regards
Re: Streaming Video not working - resolved
all
this is now resolved by installing java and setting correct path_zms as this forum solution.
http://www.zoneminder.com/forums/viewto ... 62&start=0
i now get streaming video with no error
