Hello community,
I managed to get ZoneMinder 1.25.x to start on Fedora 17 following advice from the forum and incomplete instructions in the wiki, and disabling SELinux (same page). Since one topic should be equal to "one issue", here is the SECOND issue on the road to get ZoneMinder running.
However, I am still unable to access its Web interface at (...) as it gives a 403 error.
Since there is no log in the journal viewer, I'm unsure of what is going wrong. It seems there should be no restriction related to opening the Web interface.
How do I solve this?
Error 403 when trying to access ZM 1.25.x interface (Fed.17)
Re: Error 403 when trying to access ZM 1.25.x interface (Fed
Did you modify /etc/httpd/conf.d/zoneminder.conf ? (I also responded to previous post)
Yes, as per wiki's advice, to no avail. Even purging FF's cache doesn't help.
