I'm new to zoneminder so I hope I don't ask stupid question here.
I'm trying to setup a couple of pixord P400 network cameras.
Now we use these with mplayer (record + monitor) and this works fine, I can play a stream with mplayer rtsp://10.10.10.10:554
When trying to use these camera's with zoneminder I get an error in the logs "Unable to get RTP Info Identifier from response".
I've tried to play streams in verbose mode with mplayer,openrtsp and ffmpeg and it seems to me like the camera does not provide an RTP-info line.
mplayer (and the others) do start playing, from what I've read on wikipedia RTP-info is not strictly needed, it helps to keep camera feeds in sync.
How can I best proceed to get these working (firmware is up to date - 2009 , they are a bit old, I have 30 pieces in the field) ?
Can I change the source (zm_rtsp.cpp) and set seq and rtptime to zero (not sure here what values are apropriate if they are fixed) ?
ps.mplayer recently changed some things, they used to use the live555 lib, with this lib the camera's worked great,
now they use something else and they don't work anymore, so this could be a similar problem.
Thanks in advance
RTSP question - pixord P400 - No RTP-info
Re: RTSP question - pixord P400 - No RTP-info
Thanks for your reply.
I did know the correct url for these cameras, this is not the problem.
The problem is that zoneminder expects the camera to send an RTP-info message and the camera does not (or so it appears).
I have the same issue, did you ever get it working?
thanks
thanks
