Limited to 4 network cameras???
slefevre
Post by slefevre »
I've setup a new ZM 1.25 on CentOS 5.7 i386 in a VM. I have 8 Axis cameras for this system but I can only get four to work at a time.
The syslog show the following error messages.
Jan 29 13:16:20 sc01 zmdc[3762]: WAR [Can't find process with command of 'zmc -m 6']
Jan 29 13:16:20 sc01 zmdc[8197]: INF ['zmc -m 6' started at 12/01/29 13:16:20]
Jan 29 13:16:20 sc01 zmdc[3762]: INF ['zmc -m 6' starting at 12/01/29 13:16:20, pid = 8197]
Jan 29 13:16:20 sc01 zmdc[3762]: INF ['zmc -m 6' crashed, signal 6]
Jan 29 13:16:20 sc01 zmdc[3762]: INF [Starting pending process, zmc -m 6]
Jan 29 13:16:20 sc01 zmdc[3762]: INF ['zmc -m 6' starting at 12/01/29 13:16:20, pid = 8204]
Jan 29 13:16:20 sc01 zmdc[8204]: INF ['zmc -m 6' started at 12/01/29 13:16:20]
Jan 29 13:16:20 sc01 zmdc[3762]: WAR [Can't find process with command of 'zma -m 6']
Jan 29 13:16:25 sc01 zmdc[3762]: INF [Starting pending process, zmc -m 6]
Jan 29 13:16:25 sc01 zmdc[3762]: INF ['zmc -m 6' starting at 12/01/29 13:16:25, pid = 8233]
Jan 29 13:16:25 sc01 zmdc[8233]: INF ['zmc -m 6' started at 12/01/29 13:16:25]
Jan 29 13:16:25 sc01 zmdc[3762]: INF ['zmc -m 6' crashed, signal 6]
Jan 29 13:16:29 sc01 zmdc[3762]: INF ['zmwatch.pl ' crashed, signal 6]
To troubleshoot this, I've enabled debug logging but each log for the zmc process above is empty (0 bytes).
I try to run zmc from the command line and get the following.
# zmc -m 6
Bus error
Thinking it may be related to Mmap, I've upgraded it to 0.16 via cpan but nothing changed.
I'm looking for help, suggestions, and pointers on troubleshooting this. Anyone have ideas?
Thanks!
Scott
slefevre
Re: Limited to 4 network cameras???
Post by slefevre »
To add more detail, I ran an strace on one of the monitors and the results follow.
#strace zmc -m 4
open("/lib/libnss_dns.so.2", O_RDONLY)  = 6
read(6, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\300\v\0\0004\0\0\0"..., 512) = 512
fstat64(6, {st_mode=S_IFREG|0755, st_size=21948, ...}) = 0
mmap2(NULL, 20612, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 6, 0) = 0x5c4000
mmap2(0x5c8000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 6, 0x3) = 0x5c8000
close(6)                                = 0
mprotect(0x5c8000, 4096, PROT_READ)     = 0
munmap(0xb7f9a000, 51724)               = 0
socket(PF_INET, SOCK_DGRAM, IPPROTO_IP) = 6
connect(6, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("192.168.132.50")}, 28) = 0
fcntl64(6, F_GETFL)                     = 0x2 (flags O_RDWR)
fcntl64(6, F_SETFL, O_RDWR|O_NONBLOCK)  = 0
gettimeofday({1328023371, 871924}, NULL) = 0
poll([{fd=6, events=POLLOUT}], 1, 0)    = 1 ([{fd=6, revents=POLLOUT}])
send(6, "\24\37\1\0\0\1\0\0\0\0\0\0\6cam-sn\10med-care\5loc"..., 39, MSG_NOSIGNAL) = 39
poll([{fd=6, events=POLLIN}], 1, 5000)  = 1 ([{fd=6, revents=POLLIN}])
ioctl(6, FIONREAD, [55])                = 0
recvfrom(6, "\24\37\205\200\0\1\0\1\0\0\0\0\6cam-sn\10med-care\5loc"..., 1024, 0, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("192.168.132.50")}, [16]) = 55
close(6)                                = 0
mmap2(NULL, 3076096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7c9e000
mmap2(NULL, 3076096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb79af000
mmap2(NULL, 3076096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb76c0000
open("/dev/shm/zm.mmap.4", O_RDWR|O_CREAT, 0600) = 6
fstat64(6, {st_mode=S_IFREG|0600, st_size=122881192, ...}) = 0
mmap2(NULL, 122881192, PROT_READ|PROT_WRITE, MAP_SHARED|MAP_LOCKED, 6, 0) = 0xb018f000
--- SIGBUS (Bus error) @ 0 (0) ---
+++ killed by SIGBUS +++
I've done a little googling w/ little result. It looks related to shared memory.
The file /dev/shm/zm.mmap.4 is created.
Any ideas?
Cheers,
Scott
slefevre
[SOLVED] Re: Limited to 4 network cameras???
Post by slefevre »
I've figured this out and posting here to document the solution for future users.
The short answer is this:
'Bus error' = not enough shared memory
Shared memory is allocated out of the tmpfs file system. If you run
df -h
it will show you how much memory is allocated to the tmpfs. If you do the math on how much shared memory will be needed ( http://www.zoneminder.com/wiki/index.ph ... solutions.) you can adjust the tmpfs file system in /etc/fstab.
Mine now includes:
tmpfs                   /dev/shm                tmpfs   size=1024m       0 0
I hope this helps others avoid this issue.
Cheers,
Scott
cordel
Post by cordel »
Good show and thank you for the follow up.
