hi,
I need to undo the damage this set of commands caused on a debian Squeeze box…
echo "/opt/libjpeg-turbo/lib" > /etc/ld.so.conf.d/libjpeg-turbo.conf && \
echo "/usr/local/lib" > /etc/ld.so.conf.d/ffmpeg.conf && \
echo "LD_LIBRARY_PATH=/usr/local/lib:/opt/libjpeg-turbo/lib:$LD_LIBRARY_PATH" >> /etc/bash.bashrc && \
What should I do to undo this stuff, it is causing the system to kernel panic all the time…
Help….
Re: Help….
Ok done it.tibetfreedom wrote:hi,
Fairly simple but scary...
Re: Help….
Please post what you did for others to benefit.
Re: Help….
Login as rootbb99 wrote:Please post what you did for others to benefit.
force remove two extra files…
rm -f /etc/ld.so.conf.d/libjpeg-turbo.conf
rm -f /etc/ld.so.conf.d/ffmpeg.conf
Edit this file…
nano /etc/bash.bashrc
remove two lines at bottom of file
that did it for me.
Stopped the crashes etc after a restart…
