debian wheezy and trust spotlight
marcopete87
Post by marcopete87 » Wed Dec 04, 2013 5:08 pm
hi all, i'm new to this forum (but old to zoneminder).
recentely i've update my cctv pc from fedora 8 to debian wheezy and all webcams stopped to works.
because i bought a lot of webcams and i've modified them for IR nightvision, now i must get them to work.
i tried searching on google, but with no results. :cry:
i appreciate any help.
because the system installation is new, eventually i can install an new version of fedora.
because low power processor and a lot of webcams (atom D525 with 8 webcams), i can't simply use mjpeg-streamer
the logs are:
marco@deb:~$ zmu -q -d /dev/video0 -v
Video Device: /dev/video0
General Capabilities
  Driver: uvcvideo
  Card: Trust Webcam
  Bus: usb-0000:00:1d.7-7
  Version: 0.1.0
  Type: 0x4000001
    Supports video capture (X)
    Does not support video output
    Does not support frame buffer overlay
    Does not support VBI capture
    Does not support VBI output
    Does not have tuner
    Does not have radio
    Does not support read/write i/o (X)
    Does not support async i/o
    Supports streaming i/o (X)
    Standards:
  Formats:
    YUV 4:2:2 (YUYV) (YUYV)
Crop Capabilities
  Bounds: 640 x 480
  Default: 640 x 480
  Current: Cropping is not supported
Inputs: 1
  Input 0
    Type: Camera
    Audioset: 00000000
    Standards: 0x0
    Power on  (X)
    Signal detected  (X)
    Colour Signal detected
    Horizontal Lock detected
cat /tmp/zmdc.log
12/04/13 18:00:42.095278 zmdc[2488].INF [Starting pending process, zmc -d /dev/video0]
12/04/13 18:00:42.096759 zmdc[2488].INF ['zmc -d /dev/video0' starting at 13/12/04 18:00:42, pid = 2907]
12/04/13 18:00:42.220558 zmdc[2488].ERR ['zmc -d /dev/video0' exited abnormally, exit status 6]
cat /var/log/messages
Dec  4 18:00:42 deb zmdc[2488]: INF [Starting pending process, zmc -d /dev/video0]
Dec  4 18:00:42 deb zmdc[2488]: INF ['zmc -d /dev/video0' starting at 13/12/04 18:00:42, pid = 2907]
Dec  4 18:00:42 deb zmdc[2907]: INF ['zmc -d /dev/video0' started at 13/12/04 18:00:42]
Dec  4 18:00:42 deb zmc_dvideo0[2907]: INF [Debug Level = 0, Debug Log = <none>]
Dec  4 18:00:42 deb zmc_dvideo0[2907]: INF [Starting Capture]
Dec  4 18:00:42 deb zmc_dvideo0[2907]: INF [Got signal 6 (Aborted), exiting and forcing backtrace]
marco@deb:~$ v4l-info
### v4l2 device info [/dev/video0] ###
general info
    VIDIOC_QUERYCAP
	driver                  : "uvcvideo"
	card                    : "Trust Webcam"
	bus_info                : "usb-0000:00:1d.7-7"
	version                 : 0.1.0
	capabilities            : 0x4000001 [VIDEO_CAPTURE,STREAMING]
standards
inputs
    VIDIOC_ENUMINPUT(0)
	index                   : 0
	type                    : CAMERA
	audioset                : 0
	tuner                   : 0
	std                     : 0x0 []
	status                  : 0x0 []
video capture
    VIDIOC_ENUM_FMT(0,VIDEO_CAPTURE)
	index                   : 0
	type                    : VIDEO_CAPTURE
	flags                   : 0
	description             : "YUV 4:2:2 (YUYV)"
	pixelformat             : 0x56595559 [YUYV]
    VIDIOC_G_FMT(VIDEO_CAPTURE)
	fmt.pix.width           : 640
	fmt.pix.height          : 480
	fmt.pix.pixelformat     : 0x56595559 [YUYV]
	fmt.pix.field           : NONE
	fmt.pix.bytesperline    : 1280
	fmt.pix.sizeimage       : 614400
	fmt.pix.colorspace      : SRGB
	fmt.pix.priv            : 0
controls
    VIDIOC_QUERYCTRL(BASE+0)
	type                    : INTEGER
	minimum                 : -64
	maximum                 : 64
	step                    : 1
	default_value           : 2
	flags                   : 0
    VIDIOC_QUERYCTRL(BASE+1)
	type                    : INTEGER
	minimum                 : 0
	maximum                 : 64
	step                    : 1
	default_value           : 36
	flags                   : 0
    VIDIOC_QUERYCTRL(BASE+2)
	type                    : INTEGER
	minimum                 : 1
	maximum                 : 128
	step                    : 1
	default_value           : 70
	flags                   : 0
    VIDIOC_QUERYCTRL(BASE+3)
	type                    : INTEGER
	minimum                 : -40
	maximum                 : 40
	step                    : 1
	default_value           : 0
	flags                   : 0
### video4linux device info [/dev/video0] ###
general info
    VIDIOCGCAP
	type                    : 0x1 [CAPTURE]
	channels                : 1
	audios                  : 0
	maxwidth                : 640
	maxheight               : 480
	minwidth                : 48
	minheight               : 32
channels
    VIDIOCGCHAN(0)
	channel                 : 0
	tuners                  : 0
	flags                   : 0x0 []
	type                    : CAMERA
	norm                    : 0
tuner
ioctl VIDIOCGTUNER: Invalid argument
audio
ioctl VIDIOCGAUDIO: Invalid argument
    VIDIOCGPICT
	brightness              : 33791
	hue                     : 32768
	colour                  : 35606
	contrast                : 36863
	whiteness               : 766
	depth                   : 16
	palette                 : YUYV
buffer
ioctl VIDIOCGFBUF: Invalid argument
window
    VIDIOCGWIN
	x                       : 0
	y                       : 0
	width                   : 640
	height                  : 480
	chromakey               : 0
	flags                   : 0
marcopete87
[SOLVED] Re: debian wheezy and trust spotlight
Post by marcopete87 » Thu Dec 05, 2013 8:20 am
hi all, i solved installing fedora.
goodbye debian, i'll missing you :(
