Export failed and video failes
remus
Post by remus » Tue Sep 03, 2013 1:14 am
Hi all,
have been trying to get zoneminder to work with my logitech quickcam express webcam for a few weeks, and finally had some success by downgrading from ubuntu 12.04 to ubuntu 10.04
This had the side effect of also downgrading my zoneminder version to 1.24.2
I can export still images from the primary events page, if I tick and event then click export. I can NOT export on a event details page.
I can not generate any video.
After looking around the forums I cam across this post that explains the problem is caused by the event id not being passed.
http://www.zoneminder.com/forums/viewto ... led#p72784
Hope someone can give me some help sorting this out.
Thanks for advice :)
remus
Re: Export failed and video failes
Post by remus » Tue Sep 03, 2013 1:43 am
If this helps, when I click on the video link from the events detail page, I get a page with the following url
XX.X.X.XXX/zm/index.php?view=video&eid=undefined
With the following contents
An error has occurred and this operation cannot continue.
For full details check your web logs for the code '119247'
If I open a blank tab in google chrome and manually enter the event id using the above url like this
XX.X.X.XXX/zm/index.php?view=video&eid=6
I get a page with video options, and I can generate the video :)
So to my inexperienced eyes it looks like the event id is not being passed in a few links and pages.
After using google I found a few references to a fix for the event id on line 255 in file /usr/share/zoneminder/skins/classic/includes/export_functions.php
LInk : http://www.zoneminder.com/forums/viewto ... 052#p65052
zm/skins/classic/includes/export_functions.php from:
$exportFileList = array_merge( $exportFileList, exportFileList( $eid ), $exportDetail, $exportFrames, $exportImages, $exportVideo, $exportMisc );
to:
$exportFileList = array_merge( $exportFileList, exportFileList( $eid , $exportDetail, $exportFrames, $exportImages, $exportVideo, $exportMisc ));
I've made this change, then restarted zoneminder and apache with following commands
sudo /etc/init.d/zoneminder restart
sudo /etc/init.d/apache2 restart
In all cases the eid remains undefined in the urls
Users browsing this forum: No registered users and 6 guests
