Page 1 of 1
Axis 221 IP camera
Posted: Thu Aug 29, 2013 7:35 pm
by yaskhan7
i need the Remote Host Path: of axis 221 IP camera. as i find the wiki not supported Axis 221 IP camera. i have 32 axis 221 IP camras. and i want to run it on ZoneMinder please help me.
Re: Axis 221 IP camera
Posted: Thu Aug 29, 2013 11:15 pm
by bb99
From an old post in 2011: Remote Host Path /axis-cgi/mjpg/video.cgi?resolution=320x240&compression=20
Give a try anyway
Posted: Fri Aug 30, 2013 6:46 pm
by jameswilson
As above id be amazed if an axis camera wasnt compatible. Just be careful with the maxfps string. If its not supported in the firmware then it may cause the camera to provide no image. Remove that from the default axis string and you should be fine. to test start with jpeg and work up from there
Posted: Mon Sep 09, 2013 7:00 am
by Jamez99
Thanks you for updating us with this interesting information. you did very great job. keep it up Hope you will share more ideas and pictures, I wish you good luck
