Specifying a Control Address with a port number not 80
breezly2
Post by breezly2 »
I'm trying to control a Foscam FI8918W pan/tilt with the camera http port set to 8800.
I've tried several combinations in the Control Address and Control Device fields based on previous posts.
IPADDR:PORT/decoder_control.cgi?command=0&user=operator&pwd=
I keep getting the same error: zmcontrol[24837]: ERR [Error check failed:'500 Can't connect to IPADDR:80 (connect: Connection timed out)']
Is there a way to specify the port number for the Control Address? Thanks.
