apache stops?
aztrock
apache stops?
Post by aztrock » Wed Oct 03, 2012 1:07 pm
Hello, I have a little problem with zm when I have less than a minute watching any monitor. ZoneMinder yy hangs no more load until restarting the apache ..
I searched with all possible convinations google and the forum, if alguin know a link or something to have a better idea.
root@servidor:~# sysctl -p
kernel.shmall = 167772160
kernel.shmmax = 33554432
root@servidor:~# free -m
total used free shared buffers cached
Mem: 7898 425 7472 0 38 194
-/+ buffers/cache: 192 7705
Swap: 15423 0 15423
#cat /proc/cpuinfo
processor : 7
vendor_id : GenuineIntel
cpu family : 6
model : 42
model name : Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
Manufacturer cameras are acti
any suggestions??
Carrier82
Re: apache stops?
Post by Carrier82 » Wed Oct 03, 2012 7:02 pm
Is your distribution 64 bit? I had a similar problem which may produce the symptoms you have, but I was running 1.25. Didn't solve it though as I'm now running 32 bit on a different hardware. Zoneminder working ok until you view streams might be related to the *zms process. When zm hangs, does top show anything out of the ordinary? How about logs?
http://www.zoneminder.com/forums/viewto ... 29&t=19559
aztrock
Re: apache stops?
Post by aztrock » Mon Oct 08, 2012 3:08 am
I suggest we change the system to one 32-bit?
the record does not show anything out of the ordinary occasions not buffer error, but no error or buffer error if apache hangs
Users browsing this forum: No registered users and 6 guests
