Page 1 of 1
software for android
Posted: Wed Apr 11, 2012 9:21 pm
by pystik
would prejudice an advice, you know a good software like eyezm I can use my terminal on Android??
Re: software for android
Posted: Thu Apr 12, 2012 1:03 am
by marty505
I'm using IP Camera Viewer Basic v.4.4.3 on an android based smart TV and it works just fine.
Posted: Thu Apr 12, 2012 5:56 am
by Flasheart
I use the same on an HTC Desire, but take feeds directly from the ip cameras, not via zm.
Posted: Thu Apr 12, 2012 9:31 pm
by pystik
thank you very much now I just feel
Posted: Sat Apr 28, 2012 6:48 pm
by rassi
Any one tested to turn Android phone to camera for ZM?
There is at least this app:
http://www.appbrain.com/app/ip-webcam/com.pas.webcam
Will it work with ZM?
I do have some spare Android phones and like to use them as network cameras.
Posted: Wed May 02, 2012 11:22 am
by rassi
Tested at it does work nicely
Posted: Sun Jun 03, 2012 12:35 pm
by pystik
sorry guys i scarivcato the apk but I can not set it, the brand and what should I put in the description? ZoneMinder by chance?
Posted: Mon Jun 04, 2012 7:57 pm
by zSeries
I am curios, I have an Android phone and I access the ZM via the standard browser while wi-fi connected to my home network. What will you gain by bypassing ZM? If you want to bypass ZM what are you doing here?
Posted: Fri Jun 08, 2012 2:43 pm
by Fabrizio
rassi wrote:Tested at it does work nicely
Yes, I tried it also successfully. IP Webcam even supports to switch on and off the camera LED of the phone via the web interface. Maybe I try to make a small control script for ZoneMinder so you can switch on the light from there directly.
Would work nicely to e.g. read out meters for water and power without having to go downstairs with pen and paper.
Posted: Mon Jan 02, 2017 9:23 pm
by CrisTooR
Has this script been written?
