Fedora Core 15
darkpaw
Fedora Core 15
Post by darkpaw »
Can somebody please update the wiki/docs on how to get this running in Fedora Core 15. This has changed a fair amount from previous Fedora releases. Core 16 (currently in Alpha) will likely be the same setup as 15, as well.
me2
Re: Fedora Core 15
Post by me2 »
I too am trying to install ZM on F15.
I am trying to use the precompiled ZM rpm via yum.
I am using the Centos instructions here:
http://www.zoneminder.com/wiki/index.php/CentOS
Thus far I have done the following
# yum -y install mysql mysql-server mysql-devel php php-gd php-mysql httpd gcc \
pcre-devel gd mod_ssl glib2-devel gcc-c++ ntp gnutls-devel ImageMagick
# yum -y install libjpeg-devel perl-Archive-Tar perl-MIME-Lite perl-MIME-tools \
perl-Date-Manip perl-LWP-UserAgent-Determined
# yum -y install perl-PHP-Serialization perl-Device-SerialPort perl-Archive-Zip perl-Sys-Mmap \
perl-Module-Load subversion git yasm
I will be installing zm from source and thus I probably didn't need all those packages, specifically the devel packages with the headers to compile against.
I installed them anyways.
# yum install zoneminder
# yum install ffmpeg
# systemctl start httpd.service
# systemctl start mysqld.service
# systemctl start ntpd.service
# systemctl enable ntpd.service
# systemctl enable mysqld.service
mysqld.service is not a native service, redirecting to /sbin/chkconfig.
Executing /sbin/chkconfig mysqld on
# systemctl enable httpd.service
httpd.service is not a native service, redirecting to /sbin/chkconfig.
Executing /sbin/chkconfig httpd on
# mysql
Welcome to the MySQL monitor. Commands end with ; or \g.
Your MySQL connection id is 2
Server version: 5.5.14 MySQL Community Server (GPL)
Copyright (c) 2000, 2010, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql> SET PASSWORD FOR root@localhost=PASSWORD('xxx');
Query OK, 0 rows affected (0.00 sec)
mysql> create database zm;
Query OK, 1 row affected (0.00 sec)
mysql> CREATE USER 'zm_user'@'localhost' IDENTIFIED BY 'xxx';
mysql> grant CREATE, INSERT, SELECT, DELETE, UPDATE on zm.* to zm_user@localhost
mysql> exit
Bye
The next step is supposed to be:
Import the tables into the zm database
cd /root/ZoneMinder-1.25.0
mysql -u root -p zm < db/zm_create.sql
Being that I didn't compile ZM, I didn't download the source and so I don't know where zm source is or where I should do this.
I'll look into downloading zm devel and copying the zm_create.sql to the directory that I am going to store the data in.
I wonder what options the precompiled zm is built with ?
me2
Re: Fedora Core 15
Post by me2 »
http://www.zoneminder.com/wiki/index.ph ... rom_Source
The section "Installation from RPM" says to
/usr/lib/zm/bin/zminit
However,
# rpm -ql zoneminder | grep init
/etc/rc.d/init.d/zoneminder
/usr/share/zoneminder/www/skins/classic/includes/init.php
/usr/share/zoneminder/www/skins/mobile/includes/init.php
/usr/share/zoneminder/www/skins/xml/includes/init.php
So ?????
FWIW,
# yum list zoneminder
Loaded plugins: langpacks, presto, refresh-packagekit
Installed Packages
zoneminder.i686 1.24.3-4.20110324svn3310.fc15
# uname -a
Linux zoneminder.localdomain 2.6.40.4-5.fc15.i686 #1 SMP Tue Aug 30 14:54:41 UTC 2011 i686 i686 i386 GNU/Linux
darkpaw
Re: Fedora Core 15
Post by darkpaw »
THe zm_create should have setup the database, in Fedora (earlier versions, anyways). Did you reload mysql (mysqladmin reload) after creating the database?
I got too frustrated with FC15 and just reinstalled FC14. Which is a bummer, because 14 won't be supported once 16 is released and 17 goes Alpha.
momcilosystem
Re: Fedora Core 15
Post by momcilosystem »
Did you ever make zoneminder work on F15?
