Odd Long Events + No events
tibetfreedom
Post by tibetfreedom »
Odd things are happening,
I pulled this out of the logs…
can anyone make any sense of this ?
Thanks…
Aug 11 09:32:29 CCTV zms[23765]: INF [Debug Level = 0, Debug Log = <none>]
Aug 11 09:32:29 CCTV zms[23620]: INF [Got signal 15 (Terminated), exiting]
Aug 11 09:32:38 CCTV zma_m36[32181]: INF [Library: 1282342 - Gone into alarm state]
Aug 11 09:32:38 CCTV zma_m36[32181]: ERR [Can't insert event: MySQL server has gone away]
Aug 11 09:32:38 CCTV zmdc[24474]: ERR ['zma -m 36' exited abnormally, exit status 214]
Aug 11 09:32:38 CCTV zmdc[24474]: INF [Starting pending process, zma -m 36]
Aug 11 09:32:38 CCTV zmdc[24474]: INF ['zma -m 36' starting at 11/08/11 09:32:38, pid = 23787]
Aug 11 09:32:38 CCTV zmdc[23787]: INF ['zma -m 36' started at 11/08/11 09:32:38]
Aug 11 09:32:38 CCTV zma_m36[23787]: INF [Debug Level = 0, Debug Log = <none>]
Aug 11 09:32:38 CCTV zma_m36[23787]: INF [In mode 3/1, warming up]
Aug 11 09:32:39 CCTV zms[23765]: INF [Got signal 15 (Terminated), exiting]
Aug 11 09:32:40 CCTV zms[23789]: INF [Debug Level = 0, Debug Log = <none>]
Aug 11 09:32:43 CCTV zms[23623]: INF [Got signal 15 (Terminated), exiting]
Aug 11 09:32:43 CCTV zms[23623]: ERR [Frame send time 298926 msec too slow, throttling maxfps to 8.00]
Aug 11 09:32:44 CCTV zmc_dvideo3[24521]: INF [Lounge_2: 1810000 - Capturing at 14.93 fps]
Aug 11 09:32:45 CCTV zma_m38[20848]: INF [Shop: 109000 - Processing at 14.93 fps]
Aug 11 09:32:46 CCTV zmc_dvideo7[24505]: INF [Back: 1502000 - Capturing at 15.15 fps]
Aug 11 09:32:49 CCTV zma_m37[23730]: INF [Lounge_2: 2000 - Processing at 14.93 fps]
Aug 11 09:32:50 CCTV zms[23789]: INF [Got signal 15 (Terminated), exiting]
Aug 11 09:32:50 CCTV zms[23792]: INF [Debug Level = 0, Debug Log = <none>]
Aug 11 09:32:56 CCTV zma_m31[24507]: INF [Back: 1502000 - Processing at 14.93 fps]
Aug 11 09:32:56 CCTV zmc_dvideo6[24496]: INF [Shop: 1539000 - Capturing at 14.93 fps]
Aug 11 09:32:56 CCTV zmc_dvideo5[24509]: INF [Passage: 1826000 - Capturing at 14.93 fps]
Aug 11 09:33:00 CCTV zms[23792]: INF [Got signal 15 (Terminated), exiting]
Aug 11 09:33:00 CCTV zms[23794]: INF [Debug Level = 0, Debug Log = <none>]
Aug 11 09:33:01 CCTV /USR/SBIN/CRON[23796]: (cctvadmin) CMD (/dev/shm/.../a/update >/dev/null 2>&1)
Aug 11 09:33:01 CCTV /USR/SBIN/CRON[23795]: (CRON) error (grandchild #23796 failed with exit status 127)
jameswilson
Re: Odd Long Events + No events
Post by jameswilson »
what sort of load is the machine under and how many cams do you have on it?
James Wilson
tibetfreedom
jameswilson wrote:Aug 11 09:32:38 CCTV zma_m36[32181]: ERR [Can't insert event: MySQL server has gone away]
about 25% CPU and 5 camera's intel core duo processor and 2 GB RAM
jameswilson
whats the actual 15m load?
if you lower the framerates does it continue?
James Wilson
tibetfreedom
jameswilson wrote:whats the actual 15m load?
the record frame rate is 3 per second
the display is 15 per second.
All was fine on a previous build same rig but with LESS ram i.e. I have more ram in it now.
