What Is the Optimum Resolution for Pico2000 Cards
TucsonDirect
Post by TucsonDirect » Thu Jul 28, 2011 8:30 am
Simple Question, What is the highest resolution that can be used with the Ebay Pico2000 (UCC4) Cards?
if i try some higher options i get problems with interlaced video but can read license plates, but i have to remove half of the interlacing information and the lower settings dont retain enough resolution to zoom in on the plate digitally?
So my question is what is the highest resolution that can be used with these cards without interlaced video? i.e. 320x240 640x480 740x480 etc ect?
The cameras that i am currently using are Sony CCD 1/3" 380tvl Cameras
Thanks!
mastertheknife
Re: What Is the Optimum Resolution for Pico2000 Cards
Post by mastertheknife » Thu Jul 28, 2011 9:28 am
Hi, The maximum resolution you can use is 768x576 for PAL and 640x480 for NTSC.
If you want a non-interlaced image, you need to use no higher than 384x288 for PAL (and not 352x288, because computer monitors are 4:3 unlike old CCTV monitors) and 320x240 for NTSC.
After setting the resolution to 384x288 (PAL) or 320x240 (NTSC), to get a progressive image you only need to capture the odd or the even fields (or alternate between them), you need to go to ZM options (ZM 1.24.3 and newer) and change the V4L2_CAPTURE_FIELDS option from 0 to 2, this will capture the even fields only. You can also use 7 to alternate between odd and even, but from my testing, it often results in a shaky image.
mastertheknife
Kfir Itzhak.
TucsonDirect
Post by TucsonDirect » Thu Jul 28, 2011 10:01 am
WOW! Thanks That is just what i needed to know!
I have noticed that i can record 640x480 With ok img quality but interlace problems exist however for getting plates and such Using the GPL program GIMP i can get clear images. That are higher quality than the 320x240
so if my understanding is correct it does not matter if my actual analog source is 380 or 500 TVL the img will still be the same on the dvr because much of the image information is discarded by the Cheap Capture card?
kingofkya
Post by kingofkya » Fri Jul 29, 2011 7:17 am
Cheap Capture card
Accely it is the pal and NTSC standard back from when tv was basically created. So no analog camera can go above the standard. But many home cctv cameras go below by cheating and upscaling.
TucsonDirect
Post by TucsonDirect » Sat Jul 30, 2011 6:11 am
kingofkya wrote:
Cheap Capture card
Clarify?
TucsonDirect
Post by TucsonDirect » Fri Aug 12, 2011 1:34 am
mastertheknife wrote:Hi, The maximum resolution you can use is 768x576 for PAL and 640x480 for NTSC.
mastertheknife
Is there a way to do this in 1.24.2?
jameswilson
Post by jameswilson » Fri Aug 12, 2011 7:50 pm
If pal any vertical res above 288 on an interlaced cam will cause interlace issues.
2cif is as high as you can go, which is 720/704 x 288
But the resultant image will be too wide. the windows client resizes if using this res.
James Wilson
TucsonDirect
Post by TucsonDirect » Sat Aug 13, 2011 12:06 am
jameswilson wrote:If pal any vertical res above 288 on an interlaced cam will cause interlace issues.
sorry i should have clarified, is there anyway to capture one 1 field using zm 1.24.2 ? Im using Zmlarch And have found it nearly impossible to upgrade to any newer versions :( Or even edit config files ...
I was using the Mandriva LiveCd but it was too old of a version to even ask for help in the forums :)
Thanks!
ETA:
I'm using NTSC (everything)
jameswilson
Post by jameswilson » Sat Aug 13, 2011 9:59 am
I presume its this setting?
CAPTURES_PER_FRAME
put dont see how it will help with interlacing only if its swapping between odd and and even at upto 240 vertical res.
James Wilson
mastertheknife
Post by mastertheknife » Sat Aug 13, 2011 1:17 pm
mastertheknife
Unfortunately no.
jameswilson wrote:I presume its this setting?
CAPTURES_PER_FRAME
No, its V4L2_CAPTURE_FIELDS
mastertheknife
Kfir Itzhak.
jameswilson
Post by jameswilson » Sun Aug 14, 2011 4:24 pm
mastertheknife.
Sorry my mistake.
also if you only capture the even fields it does it duplicate the info ie what is the benefit of doing this rather than just running at half vertical res?
James Wilson
mastertheknife
Post by mastertheknife » Sun Aug 14, 2011 4:30 pm
jameswilson wrote:mastertheknife.
Sorry my mistake.
To get a progressive image, instead of an interlaced image.
mastertheknife
Kfir Itzhak.
jameswilson
Post by jameswilson » Sun Aug 14, 2011 4:35 pm
so this would allow 720x576 image capture without interlace issues on a pal camera?
James Wilson
mastertheknife
Post by mastertheknife » Sun Aug 14, 2011 5:27 pm
jameswilson wrote:so this would allow 720x576 image capture without interlace issues on a pal camera?
No, but up to 384x288 for PAL and 320x240 for NTSC.
PAL for example, to capture 384x288 progressive image, the driver captures at 384x576 and ignores the even or odd lines, and this is how we get a progressive image of size 384x288 and is why its not possible over 384x288.
mastertheknife
Kfir Itzhak.
jameswilson
Post by jameswilson » Sun Aug 14, 2011 5:48 pm
ok i understand thanks
James Wilson
Users browsing this forum: No registered users and 5 guests
