issues with zonminder
justinl
Post by justinl »
im trying to set up 3 ip cameras with zoneminder they are intellinet cameras i have the correct values and everything but i cant view them. the name of the camera is the colour black, the function is monitor and it is the colour orange, the source i have set as the ip address for the camera and its the colour red. i have them set as remote view and tried others. any suggestion or help would be appreciated.
PacoLM
Re: issues with zonminder
Post by PacoLM »
Could be a shared memory problem, read this post, just to check that you didn't forgot anything http://www.zoneminder.com/forums/viewto ... 21&t=17935, if
To check shared memory settings:
http://www.zoneminder.com/forums/viewto ... ipt#p69568
Hope it helps,
PacoLM
justinl
Post by justinl »
thanks for the suggestion but it didn't work.
PacoLM
Post by PacoLM »
Let's try some more things:
1st: Are you using a non standard location for the events?
2nd: Try to reduce the buffer ring size
3rd: Some traces of /var/log/syslog when initializing zoneminder will help to reduce the search...
Regards,
PacoLM
eufreka
Post by eufreka »
justinl wrote:im trying to set up 3 ip cameras with zoneminder they are intellinet cameras i have the correct values and everything but i cant view them. the name of the camera is the colour black, the function is monitor and it is the colour orange, the source i have set as the ip address for the camera and its the colour red. i have them set as remote view and tried others. any suggestion or help would be appreciated.
Have you verified the path you are using? Paste it directly into a browser and make sure you can see the feed.
smilliken
Post by smilliken »
PacoLM wrote:Let's try some more things:
Regards,
PacoLM
I'm having a similar problem. The sources were green, but now are orange. I changed the location of the events, images and sound to another hard drive. The hard drive is mounted on boot. I have it set up as /mnt/sdc1/events...etc. I'm not sure if this is the proper format.
I have a Dlink DCS-930L and a Linksys WVC54gca attached wirelessly. Both have static IP address and are viewable in the browser.
Do the event sub directories need to be sym linked?
Simply Mepis 11 Zoneminder 1.24.2-9
Without walls.....Who needs Windows!
