Newbie - external trigger & Asterisk question?
padams
Post by padams » Fri Mar 11, 2011 8:23 pm
Aside from the regular CCTV aspect, I need to trigger an alarm from an outside source. We have a "Perimeter Fence" detection system. It has 2 outputs (one normally closed, one normally open).
What's the best way to get ZoneMinder to receive those triggers & respond? I was thinking something like the parallel port wired to it so it can detect an open or closed circuit?
I am familier with Asterisk. Does anyone have advice on getting ZoneMinder & Asterisk to work together?
I have a separate Asterisk server already. Maybe Zoneminder can produce a text file to indicate an alarm? That way, the presence or contents of that text file can trigger Asterisk to start placing phones call to alert people.
Thanks for any advice, pointers, blogs, etc...
Regards
Paul Adams
jdhar
Post by jdhar » Fri Mar 11, 2011 11:17 pm
Take a look at 'NoDect' mode for a monitor (http://www.zoneminder.com/wiki/index.ph ... onitor_Tab). The wiki has information on triggering manually.
eyeZm, Native iPhone App for ZoneMinder: http://www.eyezm.com
Version 1.3 now available on iTunes, introduces Montage view, HTTPS/SSL support and H264 native streaming!
Subscribe to RSS feed for updates: http://www.eyezm.com/rssfeed.xml
padams
Post by padams » Sat Mar 12, 2011 12:41 am
Thank you.
That lead to zmtrigger.pl - which lead to reading about using the Arduino for external events - which then lead to reading about custom scripts for firing off Asterisk.
I'm off to buy an Ardunio...
Regards
Paul Adams
Users browsing this forum: No registered users and 13 guests
