Same Display all channels
makaveli0129
Post by makaveli0129 »
OK so i've been trying to get this to work for a while now, i have a 4 channel pci card it is installed and i get a display for video0 channel 0 and as i plug in the other 3 channels i get the same as channel 0. I've unchecked the V4L_MULTI_BUFFER in the config section and also my /etc/modprobe.d/bttv.conf looks like this:
options bttv gbuffers=32 card=131,131,131,131 tuner=4,4,4,4 radio=0 coring=1 full_luma_range=1 chroma_agc=1 combfilter=1 autoload=0 triton1=0 vsfx=0
which is the tibet pro all of the options on the 4 cameras are all the same ntsc rgb24 for the palette and 352/240 for the aspect ratio
Any ideas of how to get the other channels working?
kingofkya
Post by kingofkya »
Post a screen shot of 2 of camera config
Also how manny chips does this card have currently you have it set to 4 chips with that config line.
makaveli0129
it only has one chip but 4 channels it is a single pci card so i will change that and i don't see how to post a picture in here without uploading it to some site..... i have the source as /dev/video0 channel as 1 and format as nts method as video for linux version 1 source type as local
makaveli0129
here's the updated one and i have rebooted as well...
options bttv gbuffers=32 card=131 tuner=4 radio=0 coring=1 full_luma_range=1 chroma_agc=1 combfilter=1 autoload=0 triton1=0 vsfx=0
makaveli0129
any help please this is really troublesome and i can't find the solution anywhere..........
kingofkya
Post by kingofkya »
box.net you can use to send files just upload and hit share file and copy link
post screen shots there
