Dipendence [SOLVED]
antuz88
Dipendence [SOLVED]
Post by antuz88 » Fri May 14, 2010 11:01 pm
hi...
do you know the library that i must install for these dependence?
  zoneminder: Dipende: libavcodec52 (>= 3:0.svn20090303-1) ma non è installabile oppure
                       libavcodec-unstripped-52 (>= 3:0.svn20090303-1) ma non è installabile
              Dipende: libavformat52 (>= 3:0.svn20090303-1) ma 0.svn20080206-18+lenny1 sta per essere installato oppure
                       libavformat-unstripped-52 (>= 3:0.svn20090303-1) ma non è installabile
              Dipende: libavutil49 (>= 3:0.svn20090303-1) ma 0.svn20080206-18+lenny1 sta per essere installato oppure
                       libavutil-unstripped-49 (>= 3:0.svn20090303-1) ma non è installabile
              Dipende: libpcre3 (>= 7.7) ma 7.6-2.1 sta per essere installato
              Dipende: libswscale0 (>= 3:0.svn20090303-1) ma 0.svn20080206-18+lenny1 sta per essere installato oppure
                       libswscale-unstripped-0 (>= 3:0.svn20090303-1) ma non è installabile
thanks..
[SOLVED] with
apt-get dist-upgrade
whatboy
Post by whatboy » Sat May 15, 2010 2:49 am
Did you installed ffmpeg???
whatboy
Post by whatboy » Sat May 15, 2010 2:51 am
svn checkout svn://svn.mplayerhq.hu/ffmpeg/trunk ffmpeg
./configure --enable-shared --enable-pthreads --enable-gpl --prefix=/usr/local
make
make install    <- as root and not sudo
if you have problems and need to install again, try
make clean
then repeat step (2)
Make sure package ccache is not installed...
antuz88
Post by antuz88 » Sat May 15, 2010 8:01 am
ffmpeg is installed and compiled.
if i try to install any packages return error
E: Dipendenze non soddisfatte. Provare 'apt-get -f install' senza pacchetti (o specificare una soluzione).
help pls :(
Users browsing this forum: No registered users and 20 guests
