AXIS M1011-W - not streaming
noddy
Post by noddy » Fri May 14, 2010 1:00 pm
I have just installed ZM v1.24.2 on a fresh install of Ubuntu and ZM appears to be working.
I have added the M1011-W as a remote monitor but when I open the feed or try to configure the zone there is no image stream.
Could someone provide a working configuration for a M1011-W?
Flasheart
Post by Flasheart » Sat May 15, 2010 8:26 am
Have you amended the shared memory setting as shown on the wiki?
Needed for vga ip cameras.
(Once you've got it working, let us know what it's like. I was looking at the new M range yesterday.)
antuz88
Post by antuz88 » Mon May 17, 2010 12:25 pm
paste log of /var/log/messages
henrik
Re: AXIS M1011-W - not streaming
Post by henrik » Sun May 23, 2010 6:02 pm
noddy wrote: Could someone provide a working configuration for a M1011-W?
Hi!
Here's my configuration...
Source type: Remote
Maximum FPS: (not set)
Remote protocol: HTTP
Remote Method: Simple
Remote host: user:password@192.168.0.1
Remote host port: 80
Remote host path: /axis-cgi/mjpg/video.cgi?resolution=640x480&compression=20
Image buffer size: 20
Warmup frames: 10
Initially i didn't get any stream with 640X480 using default values for image buffer and warmup frames.
Hope this helps :D
- Henrik
gorke
Post by gorke » Mon Feb 28, 2011 4:00 pm
Just get it to work like this:
Remote Protocol: http
Remote Method: simple
hostname: 192.168.0.1 (IP of your camera)
Port: 80
Host Path: / axis-cgi/mjpg/video.cgi? resolution = 320x240 & compression = 20
Color: 24 bits
Width: 320
Height: 240
Max FPS: 30.00
Alarm Max FPS: 25.00
I need to work with 640x480
Anyone?
osoroco
Post by osoroco » Mon Mar 07, 2011 3:53 pm
Hi!
Source type: Remote
Warmup frames: 10
Hope this helps :D
- Henrik
^THIS finally got some images showing on my zoneminder
a step forward
I have an Axis M3204 and an AXIS Q1755 and this did the trick for both.
Now, if I could only get real video out of them instead of mjpeg that would be awesome
newvisionantenna
Post by newvisionantenna » Tue Mar 08, 2011 1:16 pm
I just setup FOUR M1011-w cams last night on a single server with rstp/mpeg4.
Protocol RTSP
Method rtp/rtsp/http
host name admin:passwork@ip
port
path /mpeg4/media.amp
640x480
Works fine for me and hit over 30fps. I used the new DVD I put together for my setup.
Users browsing this forum: No registered users and 10 guests
