X10 WORKING in 1.24.2
kingofkya
Post by kingofkya » Sat May 01, 2010 2:35 am
OK here is what I did to get it working.
First go enable it the normal way under setting->x10
Second you need to give zm permission to use the serial port. On Ubuntu do this
sudo adduser www-data dialout
Third Fix the zm bug Status change bug.
found it on the forum but cant find it again so here is the fixed version.
http://www.box.net/shared/yht80hmo68
Forth download the missing perl libs.
perl -MCPAN -e shell
install CPAN
exit
install Sys::Mmap
exit
install YAML PHP::Serialization Module::Load X10::ActiveHome
exit
From Wiki
http://www.zoneminder.com/wiki/index.ph ... ola-0.7%29
Now restart ZM.
Testing time
Open a termianl and type
zmx10.pl -u 1 -c on
Thats should turn on device 1 on the house code you set in options.
Ok now in theory it would work if the zm interface didn't also have bugs.\
Now go to the monitor(camera) you want to interface X10 to.
Now on the main tab theres a X10 option at the bottom.
Normally selecting this will turn on the X10 related stuff but it never stays on after you hit apply. (we will get to this in a second)
Go to the X10 tab and set up the options you want. SEE: http://www.zoneminder.com/wiki/index.ph ... ion#X10_Ta
Now to fix the issues with the X10 check box you need to manually enable that check box in mysql. This is the sql query NOTE: you need to chage id=<num> to what ever monitor id you system uses.
UPDATE Monitors SET triggers = 'X10' WHERE id = 2
Heres how you run the sql query from terminal.
Logon to mysql:
mysql -p -u root
Select Database:
USE zm;
Run sql query
UPDATE Monitors SET triggers = 'X10' WHERE id = 2;
whatboy
Re: X10 WORKING in 1.24.2
Post by whatboy » Thu Jun 09, 2011 2:54 am
Any tip on what to put if I have an Insteon 2413U controller and a 2420M PIR???
Users browsing this forum: No registered users and 5 guests
