FPS Shuld change my capture card?
Papa Oso
Post by Papa Oso » Sun Apr 11, 2010 4:49 am
I'm using 4 cameras with a 4ch BT848 dvr card. When using the 4 cams at the same time each one is using about 6fps and the image has a lot of distortion But if only two are used and 15fps set as maximum everything look good. My question is Do I should buy another identical card and hook two cameras per card or buy a card with more fps capacity? I found a card advertised as 4CH 60fps on ebay. The chip set is techwell.
Thanks in advance
whatboy
Post by whatboy » Sun Apr 11, 2010 5:49 am
bing bing bing...
Driver is not quite ready...
you should buy a card with one chip one channel... the kodicom 8800 clone is not that expensive, 8 channels 8 chips...
Users browsing this forum: No registered users and 14 guests
