Issue after upgrading to 2.24.2 on Ubuntu 8.04
eBryon
Post by eBryon »
Hi, I upgraded from 2.23.3 today to 2.24.2 ZoneMinder, having an interesting variety of issues. My camera sources are mixed about 1/3 gree, 1/3 orange, and 1/3 red in the source list. Of them, if I click on any camera, it doesn't show an image at all, not even a placeholder. I can browse my old stills, but cannot view old streams or live feeds. My log files have a large quantity of the following:
Mar  2 14:12:20 camera-srvr-01 zmwatch[16347]: ERR [Can't get shared memory id '7a6d001c', 28: No such file or directory]
I'm currently running with a --disable-mmap option when I ran ./config. It didn't make a difference when I ran it with --enable-mmap=on.
All cameras were showing green and functioning fine prior to the upgrade; so I'm not sure...what I blew up. I have shmmax/shmmall set appropriately (at least for the old version).
Only thing that seems it might be causing a problem is I was previously running the Ubuntu repository version of ZM, which of course I had to upgrade from source for the new version.
Any help? More info I need to give you?
Thanks!
Edit:
I am also getting the following in my Logs, although not on the massive scale that I'm getting the above messages:
Mar  2 14:07:28 camera-srvr-01 zma_m3[18168]: ERR [Can't run query: Unknown column 'Protocol' in 'field list']
Mar  2 14:07:28 camera-srvr-01 zmdc[16094]: ERR ['zma -m 3' exited abnormally, exit status 30]
eBryon
Other info
Post by eBryon »
I recompiled with --enable-mmap=yes, and still same problem - some monitors showing green, some yellow, some red, but none of them will show the live stream. Using JPEG; both Internet Explorer and FireFox. I'm getting the errors below in the syslog now. I did check that I'm compiling with the same settings for the cgi-bin and other folders as I was using in the old setup; when I had 1.22.2 ZM all was fine. Any thoughts?
Mar  3 12:31:27 camera-srvr-01 zmwatch[6478]: ERR [Can't open memory map file '/dev/shm/.zm.mmap.27': No such file or directory]
Mar  3 12:31:27 camera-srvr-01 zmwatch[6478]: ERR [Can't open memory map file '/dev/shm/.zm.mmap.28': No such file or directory]
Mar  3 12:31:27 camera-srvr-01 zmwatch[6478]: ERR [Can't open memory map file '/dev/shm/.zm.mmap.29': No such file or directory]
lazyleopard
Post by lazyleopard »
Two thoughts:
1) You have run the appropriate database update...
2) In the "Options" -> Paths tab there's a setting for PATH_MAP which you've got set to /dev/shm (probably because that's the default). It has potentially useful help information mentioning mmap...
No idea whether either will be relevant
Rick Hewett
eBryon
Post by eBryon »
lazyleopard wrote:Two thoughts:
Funny you should mention #1; I ran across that earlier in a search (after I posted obviously) and re-ran the zmupdate.pl, told it to use an earlier ZM version. Now, I don't have those errors, and streams are functioning, but I have a black screen when trying to view a live feed, and there are errors related to capturing in my syslog. I don't have the system up at the moment so will post copies of the errors later (tired of Ubuntu wanting to run disk checks, so I figure if I let it complete one it'll quit bugging me).
