I accidentaly deleted admin user. Cannot login.
ganomi
Post by ganomi » Fri Feb 19, 2010 11:40 am
Hi.
I was playing with users and accidentally deleted last admin account. Now I am not able to login.
How can I create new account? (maybe directly in mysql?)
I guess the system should not let to delete last admin account.
Thanks for help.
mastertheknife
Post by mastertheknife » Fri Feb 19, 2010 11:47 am
Hi. You can re-create the admin account by running this query into MySQL. you can use phpmyadmin or the mysql executeable.
The password for the admin below is "changepassword"
INSERT INTO `Users` (`Id`, `Username`, `Password`, `Language`, `Enabled`, `Stream`, `Events`, `Control`, `Monitors`, `Devices`, `System`, `MaxBandwidth`, `MonitorIds`) VALUES
(1, 'admin', '*3B34B40DAE3DD1E15943B37622F688A6D7F8002D', 'en_gb', 1, 'View', 'Edit', 'Edit', 'Edit', 'Edit', 'Edit', '', '');
ganomi
Post by ganomi » Fri Feb 19, 2010 11:51 am
Thank you!
whatboy
Post by whatboy » Fri Feb 19, 2010 10:34 pm
I guess the USER should not delete last admin account.
:lol:
mysterylectricity
Re: I accidentaly deleted admin user. Cannot login.
Post by mysterylectricity » Fri Feb 17, 2017 2:32 am
This worked for me as well. For those of you who are not familiar with using mysql, the following commands are prerequisite:
mysql -u root -p
Enter password:
If you have not set an explicit password for mysql, the system root password worked for me.
Then select the zm database:
use zm;
and then:
This will set the default login to admin and the default password to changepassword.
The changes take effect immediately. Change your password and add another privileged user in case you make the same mistake again.
