Sorry Mitch somehow I missed that part about the debug log.
10/08/09 09:24:16.040690 zmc_dvideo0[10255].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.10255]
10/08/09 09:24:16.041073 zmc_dvideo0[10255].DB1-zm_monitor.cpp/1712 [Got 1 monitors]
10/08/09 09:24:16.041154 zmc_dvideo0[10255].DB2-zm_local_camera.cpp/286 [V4L2 support enabled, using V4L2 api]
10/08/09 09:24:16.041932 zmc_dvideo0[10255].DB1-zm_monitor.cpp/338 [monitor purpose=1]
10/08/09 09:24:16.041955 zmc_dvideo0[10255].DB1-zm_monitor.cpp/345 [mem.size=9217192]
10/08/09 09:24:16.055658 zmc_dvideo0[10255].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0]
10/08/09 09:24:16.058028 zmc_dvideo0[10255].DB1-zm_monitor.cpp/458 [Monitor Monitor-1 has function 2]
10/08/09 09:24:16.058045 zmc_dvideo0[10255].DB1-zm_monitor.cpp/459 [Monitor Monitor-1 LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
10/08/09 09:24:16.058057 zmc_dvideo0[10255].DB1-zm_monitor.cpp/460 [Monitor Monitor-1 IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
10/08/09 09:24:16.058284 zmc_dvideo0[10255].DB1-zm_zone.cpp/889 [Got 1 zones for monitor Monitor-1]
10/08/09 09:24:16.058306 zmc_dvideo0[10255].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 319,0 319,239 0,239]
10/08/09 09:24:16.058321 zmc_dvideo0[10255].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 319,0 319,239 0,239']
10/08/09 09:24:16.058335 zmc_dvideo0[10255].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
10/08/09 09:24:16.058346 zmc_dvideo0[10255].DB3-zm_zone.cpp/796 [Got coordinate 319,0 from polygon string]
10/08/09 09:24:16.058357 zmc_dvideo0[10255].DB3-zm_zone.cpp/796 [Got coordinate 319,239 from polygon string]
10/08/09 09:24:16.058368 zmc_dvideo0[10255].DB3-zm_zone.cpp/796 [Got coordinate 0,239 from polygon string]
10/08/09 09:24:16.058383 zmc_dvideo0[10255].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
10/08/09 09:24:16.058396 zmc_dvideo0[10255].DB1-zm_zone.cpp/50 [Initialised zone 2/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:2304, MxAP:57600, FB:3x3, MnFP:2304, MxFP:57600, MnBS:1536, MxBS:0, MnB:1, MxB:0, OF: 0]
10/08/09 09:24:16.060602 zmc_dvideo0[10255].DB1-zm_monitor.cpp/1814 [Loaded monitor 2(Monitor-1), 1 zones]
10/08/09 09:24:16.060621 zmc_dvideo0[10255].INF-zmc.cpp/188 [Starting Capture]
10/08/09 09:24:16.060885 zmc_dvideo0[10255].DB3-zm_local_camera.cpp/349 [Opening video device /dev/video0]
10/08/09 09:24:16.060930 zmc_dvideo0[10255].DB2-zm_local_camera.cpp/355 [V4L2 support enabled, using V4L2 api]
10/08/09 09:24:16.060944 zmc_dvideo0[10255].DB3-zm_local_camera.cpp/360 [Checking video device capabilities]
10/08/09 09:24:16.060965 zmc_dvideo0[10255].DB3-zm_local_camera.cpp/370 [Setting up video format]
10/08/09 09:24:16.060996 zmc_dvideo0[10255].FAT-zm_local_camera.cpp/386 [Failed to set video format: Invalid argument]
10/08/09 09:24:16.061373 zmc_dvideo0[10255].INF-zm_signal.cpp/64 [Got signal 6 (Aborted), exiting and forcing backtrace]
10/08/09 09:24:16.061509 zmc_dvideo0[10255].ERR-zm_signal.cpp/84 [Signal address is (nil), from 0xb806e430]
10/08/09 09:24:16.061779 zmc_dvideo0[10255].ERR-zm_signal.cpp/122 [Backtrace: [0xb806e430]]
10/08/09 09:24:16.061856 zmc_dvideo0[10255].ERR-zm_signal.cpp/122 [Backtrace: [0xb806e430]]
10/08/09 09:24:16.061898 zmc_dvideo0[10255].ERR-zm_signal.cpp/122 [Backtrace: /lib/tls/i686/cmov/libc.so.6(gsignal+0x50) [0xb7b796d0]]
10/08/09 09:24:16.061953 zmc_dvideo0[10255].ERR-zm_signal.cpp/122 [Backtrace: /lib/tls/i686/cmov/libc.so.6(abort+0x188) [0xb7b7b098]]
10/08/09 09:24:16.062002 zmc_dvideo0[10255].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x805582d]]
10/08/09 09:24:16.062051 zmc_dvideo0[10255].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x80688cf]]
10/08/09 09:24:16.062100 zmc_dvideo0[10255].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x80691a4]]
10/08/09 09:24:16.062148 zmc_dvideo0[10255].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x804c4db]]
10/08/09 09:24:16.062197 zmc_dvideo0[10255].ERR-zm_signal.cpp/122 [Backtrace: /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5) [0xb7b64775]]
10/08/09 09:24:16.062246 zmc_dvideo0[10255].ERR-zm_signal.cpp/122 [Backtrace: /usr/local/bin/zmc [0x804c041]]
10/08/09 09:24:16.062295 zmc_dvideo0[10255].INF-zm_signal.cpp/125 [Backtrace complete, please execute the following command for more information]
10/08/09 09:24:16.062354 zmc_dvideo0[10255].INF-zm_signal.cpp/126 [addr2line -e /usr/local/bin/zmc 0xb806e430 0xb806e430 0xb7b796d0 0xb7b7b098 0x805582d 0x80688cf 0x80691a4 0x804c4db 0xb7b64775 0x804c041]
