ZMlarch CD, what steps to install it on drive as system ?
electron
Post by electron »
I don't normally use live CD's but recently switched to arch from fedora, was playing with the ZMLarch live CD. Is there a way to install it onto the harddrive from the live CD ?
akke
Post by akke »
It's a icon on the top left witch lets you install to HD.
After it's installed, edit /etc/hosts and remove the underscores and numbers after zmhost.
electron
Post by electron »
Thanks, I didn't get X to start, I get error message of (EE) config/hal new input device request failed ( number eight here) , am still trying to solve that. I did run hwd -X as root & renamed the file xorg.conf, but have that error message still. I put ^^^^^^^^^^ cuz the nimber 8 in () makes an emoticon appear !
