Questions From and OLD (hehe) friend
victor_diago
Post by victor_diago »
Hi everybody !
Specially Phil and Jameswilson (Curtishall i still loves you, macieck too)
I have been a long time without posting because i was not dealing a lot with zoneminder !
I would like to understand this new world of mpeg and rtsp câmeras !
How do ZM stores the images ? it stores in avi/mpeg files or still in jpeg ?
Can i store audio ? for example, if my ip cam stream audio in rtsp ?
Thanks for your wonderful work phil ! You are a great guy !
curtishall
Re: Questions From and OLD (hehe) friend
Post by curtishall »
Files are still recorded as jpeg. Audio is not supported..though it wouldn't be as hard to stream audio to a file as it would be with analog cameras.
victor_diago wrote:Hi everybody !
Curtis Hall
Bluecherry
www.bluecherrydvr.com
store.bluecherry.net
victor_diago
Hmmmm Ok, i understand !
Well, i will try to make some changes on it. I will need a way to store as avi, so its easy to store audio also !
Im gone to the project table !
Thanks !
Victor Diago
