My problems compiling with ffmpeg support on FC10
Blazer
Post by Blazer »
I can see that configure is not finding the ffmpeg libs:
checking libavutil/avutil.h usability... no
checking libavutil/avutil.h presence... no
checking for libavutil/avutil.h... no
checking ffmpeg/avutil.h usability... no
checking ffmpeg/avutil.h presence... no
checking for ffmpeg/avutil.h... no
checking libavcodec/avcodec.h usability... no
checking libavcodec/avcodec.h presence... no
checking for libavcodec/avcodec.h... no
checking ffmpeg/avcodec.h usability... no
checking ffmpeg/avcodec.h presence... no
checking for ffmpeg/avcodec.h... no
checking libavformat/avformat.h usability... no
checking libavformat/avformat.h presence... no
checking for libavformat/avformat.h... no
checking ffmpeg/avformat.h usability... no
checking ffmpeg/avformat.h presence... no
checking for ffmpeg/avformat.h... no
checking libswscale/swscale.h usability... no
checking libswscale/swscale.h presence... no
checking for libswscale/swscale.h... no
checking ffmpeg/swscale.h usability... no
checking ffmpeg/swscale.h presence... no
checking for ffmpeg/swscale.h... no
Here is where my libs are actually located:
# rpm -ql ffmpeg-devel
/usr/include/ffmpeg
/usr/include/ffmpeg/libavcodec
/usr/include/ffmpeg/libavcodec/avcodec.h
/usr/include/ffmpeg/libavcodec/opt.h
/usr/include/ffmpeg/libavdevice
/usr/include/ffmpeg/libavdevice/avdevice.h
/usr/include/ffmpeg/libavfilter
/usr/include/ffmpeg/libavfilter/avfilter.h
/usr/include/ffmpeg/libavformat
/usr/include/ffmpeg/libavformat/avformat.h
/usr/include/ffmpeg/libavformat/avio.h
/usr/include/ffmpeg/libavformat/rtsp.h
/usr/include/ffmpeg/libavformat/rtspcodes.h
/usr/include/ffmpeg/libavutil
/usr/include/ffmpeg/libavutil/adler32.h
/usr/include/ffmpeg/libavutil/avstring.h
/usr/include/ffmpeg/libavutil/avutil.h
/usr/include/ffmpeg/libavutil/base64.h
/usr/include/ffmpeg/libavutil/common.h
/usr/include/ffmpeg/libavutil/crc.h
/usr/include/ffmpeg/libavutil/fifo.h
/usr/include/ffmpeg/libavutil/intfloat_readwrite.h
/usr/include/ffmpeg/libavutil/log.h
/usr/include/ffmpeg/libavutil/lzo.h
/usr/include/ffmpeg/libavutil/mathematics.h
/usr/include/ffmpeg/libavutil/md5.h
/usr/include/ffmpeg/libavutil/mem.h
/usr/include/ffmpeg/libavutil/random.h
/usr/include/ffmpeg/libavutil/rational.h
/usr/include/ffmpeg/libavutil/sha1.h
/usr/include/ffmpeg/libpostproc
/usr/include/ffmpeg/libpostproc/postprocess.h
/usr/include/ffmpeg/libswscale
/usr/include/ffmpeg/libswscale/rgb2rgb.h
/usr/include/ffmpeg/libswscale/swscale.h
/usr/lib/libavcodec.so
/usr/lib/libavdevice.so
/usr/lib/libavfilter.so
/usr/lib/libavformat.so
/usr/lib/libavutil.so
/usr/lib/libpostproc.so
/usr/lib/libswscale.so
/usr/lib/pkgconfig/libavcodec.pc
/usr/lib/pkgconfig/libavdevice.pc
/usr/lib/pkgconfig/libavfilter.pc
/usr/lib/pkgconfig/libavformat.pc
/usr/lib/pkgconfig/libavutil.pc
/usr/lib/pkgconfig/libpostproc.pc
/usr/lib/pkgconfig/libswscale.pc
/usr/lib/sse2/libavcodec.so
/usr/lib/sse2/libavdevice.so
/usr/lib/sse2/libavfilter.so
/usr/lib/sse2/libavformat.so
/usr/lib/sse2/libavutil.so
/usr/lib/sse2/libpostproc.so
/usr/lib/sse2/libswscale.so
Here is a sample of the errors I get when I try to run make:
# make
make  all-recursive
make[1]: Entering directory `/tmp/ZoneMinder-1.24.0'
Making all in src
make[2]: Entering directory `/tmp/ZoneMinder-1.24.0/src'
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include  -frepo -g -O2 -MT zmc.o -MD -MP -MF .deps/zmc.Tpo -c -o zmc.o zmc.cpp
In file included from zm_mpeg.h:23,
                 from zm_stream.h:27,
                 from zm_event.h:39,
                 from zm_zone.h:27,
                 from zm_monitor.h:28,
                 from zmc.cpp:28:
zm_ffmpeg.h:33:2: error: #error "No location for avutils.h found"
zm_ffmpeg.h:40:2: error: #error "No location for avcodec.h found"
zm_ffmpeg.h:47:2: error: #error "No location for avformat.h found"
zm_ffmpeg.h:55:2: error: #error "No location for swscale.h found"
This is the configure option I am currently using:
# ./configure --with-mysql=/usr/lib/mysql --with-ffmpeg=/usr/lib --with-extralibs="-lmp3lame -L/usr/lib/mysql" --with-webdir=/var/www/html --with-cgidir=/var/www/cgi-bin
Any suggestions are much appreciated.
nuck
Re: My problems compiling with ffmpeg support on FC10
Post by nuck »
Blazer wrote:This is the configure option I am currently using:
Try
./configure --with-webdir=/var/www/html --with-cgidir=/var/www/cgi-bin
and see where that gets you. People insist on providing options to configure that are redundant (or just plain wrong).. Give configure a chance to figure things out on it's own and go from there.
maciekc
Post by maciekc »
Blazer wrote: This is the configure option I am currently using:
It should be: --with-ffmpeg=/usr
# ./configure --with-mysql=/usr/lib/mysql --with-ffmpeg=/usr --with-extralibs="-lmp3lame -L/usr/lib/mysql" --with-webdir=/var/www/html --with-cgidir=/var/www/cgi-bin
zoneminder
Site Admin
Post by zoneminder »
Unless ffmpeg is somewhere other than in the usual places under /usr/ or /usr/local then don't bother with the with-ffmpeg option as it should find it.
Phil
mklein
hmmm...
Post by mklein »
Doesn't this contradict another manual reference which says to use "/usr/bin" for ffmpeg? (or whatever dir parent is).
I think I used "/usr/local" at first (for handbuilt ffmpeg) and later when I used "/usr/local/bin" the cfg script did seem to pick up more ffmpeg in output.
mike
Blazer
Post by Blazer »
Try
The webdir options have nothing to do with finding the ffmpeg libraries? I gave it a whirl anyway, still same errors.
Blazer
Post by Blazer »
I tried that and still same errors:
./configure --with-webdir=/var/www/html --with-cgidir=/var/www/cgi-bin --with-mysql=/usr/lib/mysql --with-ffmpeg=/usr --with-extralibs="-lmp3lame -L/usr/lib/mysql" --with-webdir=/var/www/html --with-cgidir=/var/www/cgi-bin
Blazer
Post by Blazer »
zoneminder wrote:Unless ffmpeg is somewhere other than in the usual places under /usr/ or /usr/local then don't bother with the with-ffmpeg option as it should find it.
Okay now tried leaving out --with-ffmpeg option, still same errors. At this point Im suspecting it is some oddity with the version of ffmpeg that I am using, although it worked fine with 1.23.x
mklein
Post by mklein »
Have you rebuilt ffmpeg? What version of zm/ffmpeg are you using?
Trying to compile zm against pre-buit ffmpeg will fail usually I think.
You will have to grab ffmpeg, make edit to single line in rtsp cpp file, rebuild, then build zm.
These steps worked for me on ubuntu 8.10.
zoneminder
Site Admin
Re: hmmm...
mklein wrote:Doesn't this contradict another manual reference which says to use "/usr/bin" for ffmpeg? (or whatever dir parent is).
There are two separate things here. Configure locates the ffmpeg libraries and headers for building. There is also an option to locate the ffmpeg binary which is used to generate videos. It is likely that the second could be derived from the first I guess.
Phil
Blazer
Re: hmmm...
Post by Blazer »
Exactly...in my case it is locating the ffmpeg libs and headers that is failing.
zoneminder
Site Admin
Why are you using these options?
Neither should be necessary. If you look in config.log you might find that the errors to do with the ffmpeg headers are actually failures related to this.
Phil
mklein
my configuration to build ffmpeg/zm
Post by mklein »
For building zm I apparently used the following (configure.mdk...my custom config):
./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin ZM_DB_PASS=<dontyouwish> --with-libarch --with-webuser=www-data --with-webgroup=www-data --with-ffmpeg=/usr/local/bin
--enable-debug=yes ZM_SSL_LIB=openssl
The with-libarch params is cause I'm on 64-bit...not sure if necessary.
I used the following to build ffmpeg:
mklein@father:/usr/local/src/zm$ cat ../ffmpeg/configure.mdk
#!/bin/bash
./configure --enable-gpl --enable-swscale --enable-shared --enable-pthreads
I may have screwed up -with-ffmpeg param in zm build....but to my recollection configure found ffmpeg in ALL cases during config.
At least I get a workable build.
Blazer
Post by Blazer »
zoneminder wrote:Why are you using these options?
If I do not use that extralibs option, I get this error:
checking for mysql_init in -lmysqlclient... no
configure: error: zm requires libmysqlclient.a
So thats why Im using those options. I will take a closer look at the config.log to see if it reveals anything
mklein
Post by mklein »
On my box libmysqlclient.a is in /usr/lib and NOT /usr/lib/mysql.
mklein@father:/usr$ ls /usr/lib/*mysql*
/usr/lib/libmysqlclient.a    /usr/lib/libmysqlclient_r.la     /usr/lib/libmysqlclient_r.so.15.0.0  /usr/lib/libmysqlclient.so.15.0.0
/usr/lib/libmysqlclient.la   /usr/lib/libmysqlclient_r.so     /usr/lib/libmysqlclient.so
/usr/lib/libmysqlclient_r.a  /usr/lib/libmysqlclient_r.so.15  /usr/lib/libmysqlclient.so.15
/usr/lib/mysql:
libdbug.a  libmyisam.a     libmysqld.a     libmysys.a      libndbclient.la  libndbclient.so.2      libvio.a
libheap.a  libmyisammrg.a  libmystrings.a  libndbclient.a  libndbclient.so  libndbclient.so.2.0.0
mklein@father:/usr$
