cannot start zm
freak
cannot start zm
Post by freak »
I'm trying to get 1.24.0 working and have been dealing with ffmpeg. Zm never starts and zmpkg.log shows
 02/13/09 14:50:24.187448 zmpkg[12705].ERR [Unable to run "/usr/local/bin/zmfix", output is ""]
Running zmfix or ffmpeg from the command line gives the following error...
zmfix: symbol lookup error: /usr/local/lib/libavcodec.so.52: undefined symbol: av_gcd
I followed the instructions at http://ubuntuforums.org/showthread.php?t=786095 exactly to get ffmpeg working.
Any tips?[/code]
nuck
Re: cannot start zm
Post by nuck »
freak wrote:Any tips?
Yup.. Apparently for some stupid reason any given ubuntu install may or may not (??) have /usr/local/lib included in /etc/ld.so.conf so try this ---
$ cat /etc/ld.so.conf
if `/usr/local/lib` is not in the file, add it
$ echo "/usr/local/lib" >> /etc/ld.so.conf
and then run
$ ldconfig
and see if that helps.
Run ldconfig anyway since make install with ffmpeg may not be doing it either.
souverain
Re: cannot start zm
Post by souverain »
Had the same or similar issue. Tried the suggestions here without any change, but
zmupdate.pl -f
resolved the issue.
-S
and then run
$ ldconfig
nuck
Re: cannot start zm
Post by nuck »
souverain wrote:Had the same or similar issue. Tried the suggestions here without any change, but
zmupdate.pl -f
resolved the issue.
-S
That will update the databases. I'm not so sure about fixing unresolved symbol (library issues).
