Is Gadspot GS1600H lens adjustable?mine looks so blury and i tried to adjust it from the basic setting pages, but doesn't work. anyone had ecperienced this before?
thanks.
Gadspot GS1600H focus
Physically twist the ring around the lens - they have different lenses, some have a little lever on the collar which adjusts it.
Only the very top-end cameras have automatic focus.
If installed already, I find taking a camera with me or having someone at a computer with a walkie-talkie or mobile saves a LOT of time.
Otherwise - get a good focus in your office during initial config before you install. Focal length tends to be very short so once you've got it, it should be good whereever.
