how do I get input from composite 1,2,3?
u238
Post by u238 » Fri Sep 30, 2005 11:06 am
Hi all,
I've recently installed zm and all the stuff, but i don't know how to get the video stream from different composite connector.. I can only watch the input of the first connector ..how can I get the others working?
i've tryed with xawtv, but it showes up only composite1, s-video, and composite3, but composite3 doesn't work.
my card is a Impact VCB Model.64405 Rev.C1, she has 3 composite input and a S-video input.
here my dmesg:
Linux video capture interface: v1.00
bttv: driver version 0.9.15 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Host bridge needs ETBF enabled.
bttv: Bt8xx card found (0).
ACPI: PCI Interrupt 0000:00:14.0[A] -> Link [LNKD] -> GSI 10 (level, low) -> IRQ 10
bttv0: Bt878 (rev 17) at 0000:00:14.0, irq: 10, latency: 64, mmio: 0xe8001000
bttv0: detected: Hauppauge WinTV [card=10], PCI subsystem ID is 0070:13eb
bttv0: using: Hauppauge (bt878) [card=10,autodetected]
bttv0: enabling ETBF (430FX/VP3 compatibilty)
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: Hauppauge/Voodoo msp34xx: reset line init [5]
tveeprom: Hauppauge: model = 64405, rev = C1  , serial# = 8232218
tveeprom: tuner = Unspecified (idx = 2, type = 4)
tveeprom: tuner fmt = unknown1 (eeprom = 0x01, v4l2 = 0x00000000)
tveeprom: audio_processor = None (type = 0)
bttv0: using tuner=4
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
tvaudio: TV audio decoder + audio/video mux driver
tvaudio: known chips: tda9840,tda9873h,tda9874h/a,tda9850,tda9855,tea6300,tea6320,tea6420,tda8425,pic16c54 (PV951),ta8874z
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: registered device radio0
bttv0: PLL: 28636363 => 35468950 .. ok
Gentoo Linux on AMD64
jameswilson
Post by jameswilson » Fri Sep 30, 2005 12:08 pm
login as root
find modprope.conf in the /etc file
add
options bttv card=82
to this file save it
reboot and you should have all your inputs available
Btw is this the 4x bnc one or the 3 phono and svhs one
James
u238
Post by u238 » Fri Sep 30, 2005 12:33 pm
my card is that in the image ( Impact VCB Model.64405 Rev.C1):
jameswilson
Post by jameswilson » Fri Sep 30, 2005 1:07 pm
yeah thats card=82
u238
Post by u238 » Fri Sep 30, 2005 1:18 pm
thanks... but i can't visualize any image in zoneminder....
...the PC is not near me in this time, so i can't check if with tvtime the video showes up (i'm managing via ssh), but in zoneminder nothing is visualized.
My settings are:
device: /dev/video0 channel: 0
device: /dev/video0 channel: 1
device: /dev/video0 channel: 2
...but no one shows me an image... what is wrong? ...i've set the function to "monitor" just for testing..
jameswilson
Post by jameswilson » Fri Sep 30, 2005 2:30 pm
have you set modprobe to card 82
James
u238
Post by u238 » Fri Sep 30, 2005 2:36 pm
yes. I've followed your instructions to make load the module correctly after any reboot (modifying the /etc/modprobe.conf), and loaded the module:
modprobe bttv card=82
jameswilson
Post by jameswilson » Fri Sep 30, 2005 5:11 pm
you may know more than me here but i usually edit modprobe.conf to include the card info and reboot not sure what the other statement does.
If you have modified the modprobe.conf na drebooted you should see the inputs. I have a vcb card do running my cams at home
James
