X10 How it works ???
rfuentes
Post by rfuentes » Sat Sep 24, 2005 11:18 pm
Over serial port ???, ethernet port ???. Do you need a serial to X10 converter ??? Any help is really appreciated
Regards
jameswilson
Post by jameswilson » Sat Sep 24, 2005 11:56 pm
zm is currently able to use x10 over the serial port. If you check options in zm then click the x10 tab you will see the port that zm will chack for an x10 interface. Unfortunatly I have never used this and i only know the above from reading the manual.
James
