got a cord from ebay and its detected by linux, but the images captured are all out of sync. I am using a proven pal camera and image just rolls. If i chabge input to ntsc i got a horible but better image (b/w only) Any ideas what to do to help??
It may be wise to but a heat sink on it. I have two cards that have gone bad now over the last year. The 878 chips were not designed for switching as we make it do constantly and working the trasistors like that seems to produce a bit more heat than if you were only having set on one input.
I have 4ch 1 chip card from Ebay also. Nice price. Hardware configuration
shows it is bt878. How do I change card type to 77amd. At the moment
it displays just as you discribe.
find a file called modprobe.conf in the etc folder and add a line at the bottom that reads
bttv options card=77
if you have multiple chips of the same type add 77 per chip seperated by a ,
