monitoring temps
monitoring temps
Hi gurus, Anyone know how i can monitor the temps and fan speeds of my zm box?
Hi jameswilson
Depending on how new your hardware is in your machine and what distro you are using u can allways use the following. : http://phpsysinfo.sourceforge.net/
This software will give you alot of info on your box, and this is allso acceble over the net, so no need to sit at the box to check howe hot it is.
Best Regards
Tom Stage
Tom Stage
Re: monitoring temps
You want the "lm_sensors" package. You can get it from: http://secure.netroedge.com/~lm78/jameswilson wrote:Hi gurus, Anyone know how i can monitor the temps and fan speeds of my zm box?
lm_sensors lets you read the builtin fan speed and temperature sensors that are built into most motherboards.
Note that lm_sensors is a prerequesite of using phpsysinfo.
