big system - 20-30 cameras
Posted: Mon Jun 06, 2005 9:56 am
Hi!
I used 4 input card bt878 based, how many of them I can insert to PCI?
I tried only 3. I read that the maximum number of card inserted is 4. Do you have any experience with 5 or 6 cards?
Do you know some board that supports 8 or 16 cameras and works well with zoneminder?
I found spectra8 card.
Is it working with zoneminder with all 8 inputs at the same time?
Can I insert 4 cards at the same time?
Maybe you have some other solution?
Is there other chipset than bt878 that have good driver for linux?
Thanks for any solution!
