OV511 chip doesn't work with 2.6.11 :(
gungner
Post by gungner » Tue May 17, 2005 6:08 am
I just upgraded to Mandriva 2005 which comes with kernel 2.6.11 and my USB cameras doesn't work any more :( I found this :
"ov511-2.28 driver does not work under linux 2.6.11 for three reasons: 1. remap_page_range does not exist (The log message is \"ov511: Unknown symbol remap_page_range\") 2. USB parameters idProduct and idVendors are kept in little endian format (previous kernels converted those data in cpu format) 3. usb_unlink_urb is deprecated (messages and stack dumps on the logs), usb_kill_urb must be used instead for synchronous streams. 1. and 3. affect all the systems while 2. appears only on Big Endian computers (with log error messages like: \"Unknown product ID 0x1105\"). I wrote a patch, see http://www.bononia.it/~renzo/keap/ Please insert the patch in the mainstream. Do not forget to put a tiny \"credit\" for the bugfix."
I'm a bit stuck now what to do, is it to recompile the driver and install the new one. Anyone done it already?'
cheers, tord
hrabe
Post by hrabe » Tue May 17, 2005 9:40 am
I have 2.6.11.8 kernel and driver ov511 (with Creative Labs WebCam 3) works fine.
Martin
gungner
Post by gungner » Tue May 17, 2005 4:40 pm
That's good to know, thanks. When I plug my creative webcam III I get the following from dmesg.
3rdparty/ov511/ov511_core.c: USB OV511 video device found
3rdparty/ov511/ov511_core.c: model: Creative Labs WebCam 3 (id=21)
3rdparty/ov511/ov511_core.c: Device at usb-0000:00:10.1-1 registered to minor 0
kobject_register failed for ov511 (-17)
[<c0103c8e>] dump_stack+0x1e/0x20
[<c02143fb>] kobject_register+0x5b/0x70
[<c0281e51>] bus_add_driver+0x71/0xd0
[<c02824c1>] driver_register+0x31/0x40
[<f883816a>] usb_register+0x4a/0xb0 [usbcore]
[<f8c66013>] usb_ov511_init+0x13/0x36 [ov511]
[<c018a952>] sys_init_module+0x1e2/0x270
[<c0102e5d>] sysenter_past_esp+0x52/0x75
usbcore: error -17 registering driver ov511
/var/log/message gives:
May 17 18:35:43 srv kernel: 3rdparty/ov511/ov511_core.c: USB OV511 video device found
May 17 18:35:43 srv kernel: 3rdparty/ov511/ov511_core.c: model: Creative Labs WebCam 3 (id=21)
May 17 18:35:43 srv kernel: 3rdparty/ov511/ov511_core.c: Device at usb-0000:00:10.1-1 registered to minor 0
May 17 18:35:44 srv kernel: kobject_register failed for ov511 (-17)
May 17 18:35:44 srv kernel: [pg0+947761171/1068971008] usb_ov511_init+0x13/0x36 [ov511]
May 17 18:35:44 srv kernel: [<f8c66013>] usb_ov511_init+0x13/0x36 [ov511]
May 17 18:35:44 srv kernel: usbcore: error -17 registering driver ov511
It just doesn't work after the upgrade. How you upgraded or installed from scratch?
cheers,tord
hrabe
Post by hrabe » Tue May 17, 2005 7:14 pm
I have vanilla kernel from source with no patch.
dmesg:
drivers/usb/media/ov511.c: USB OV511 video device found
drivers/usb/media/ov511.c: model: Creative Labs WebCam 3
drivers/usb/media/ov511.c: Sensor is an OV7610
drivers/usb/media/ov511.c: Device at usb-0000:00:0f.2-2 registered to minor 6
usbcore: registered new driver ov511
drivers/usb/media/ov511.c: v1.64 for Linux 2.5 : ov511 USB Camera Driver
Martin
gungner
Post by gungner » Wed May 18, 2005 6:03 am
thanks, I think I'm using version 2.28 which seems to differ from your setup. I'll try "downgrade" and see how it goes.
cheers, tord
Users browsing this forum: No registered users and 12 guests
