I am trying to get a Spectra-8 card to work under Fedora Core 2 (kernel v. 2.6.6-1.435).
The instruction on the www.bytesex.org site for the bttv-0.9.15 drivers is cryptic to say the least. I tried downloading the "patch-2.6.6-kraxel" file and after installing the kernel rpm but when I tried applying the patch it has many errors.
I upgraded my Core 1 install to Core 2 to get the support for V4L2 (I never got the card to work uner FC1 due to the latest yum updated kernel was 2.4.22 and the patches availiable on the bytesex site started at 2.4.25).
I have ZM installed and ready go as soon as soon as I get the PCI video capture card installed and figured out. When I physically installed the card, kudzu detected and installed the Brooktree Video Card four times (once for each controller chip on the card).
I installed xawtv to test for video input. Here is the results from xawtv -hwscan:
__________________________________________________
This is xawtv-3.88, running on Linux/i686 (2.6.6-1.435)
looking for available devices
port 56-56
type : Xvideo, image scaler
name : SIS 300/315/330 series Video Overlay
/dev/video0: OK [ -device /dev/video0 ]
type : v4l2
name : BT878 video (ProVideo PV951)
flags: overlay capture tuner
/dev/video1: OK [ -device /dev/video1 ]
type : v4l2
/dev/video2: OK [ -device /dev/video2 ]
type : v4l2
/dev/video3: OK [ -device /dev/video3 ]
type : v4l2
Here is the output from xawtv when I try xawtv -d /dev/video0 (I get a video window that opens then imediately closes):
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 144 (GLX)
Minor opcode of failed request: 5 (X_GLXMakeCurrent)
Serial number of failed request: 464
Current serial number in output stream: 464
____________________________________________________
Any help getting this up and going would be greatly appreciated.
Scott
Spectra-8 Card on Fedora Core 2
Anyone there that can help?
Is there anyone here that can either help me with this problem or refer me to somewhere where I can optain help?
Scott
Scott
