Page 1 of 1
Read This Before Posting
Posted: Wed Apr 14, 2004 11:18 am
by zoneminder
Posted: Fri Feb 22, 2008 7:23 pm
by cordel
You should also check
our Wiki HCL and the HCL for your Distro.
It's always a good idea to google on the hardware your considering just to make sure it has no problems. ie. in the google search string you could do
to search our domain only for other users experiences.
Posted: Fri Jul 11, 2008 12:55 am
by Lee Sharp
And when your card does not work, realize that there are hundreds of different cards. And each one is often branded with many different names. A name, link, and picture can really help a lot. If I see a post with "I have China Special PX-1234 and it doesn't work" and that is all, I have no answer to give.
Re: Read This Before Posting
Posted: Tue May 03, 2016 12:58 pm
by caseyj
Also
Before I try to get a camera to work on Zoneminder, I try to look at it using the Swiss Army Knife of video tools, the VLC Player. Just download the player and put the following url into the File/Open Network dialog box...
More...
https://wiki.zoneminder.com/Dahua.. Look for
Confirming Camera is On Your Network
Posted: Tue Mar 14, 2017 7:58 am
by michael_80
Hi there,
Just wanted to let you know the link
http://www.zoneminder.com/support.html you posted here is not working, it gives 404 Not Found.
Posted: Wed Feb 03, 2021 3:13 pm
by whatzhisface
The link in the initial "read this" post for checking hardware compatibility is broken.
I found this in the wiki
https://wiki.zoneminder.com/Hardware_Compatibility_List
Posted: Sun Oct 17, 2021 2:38 pm
by dvl
zoneminder wrote: ↑Wed Apr 14, 2004 11:18 am
Before asking about a hardware support please check
here and in the Hardware Compatibility List first.
Both of these links are 404.
Posted: Sun Oct 17, 2021 3:25 pm
by iconnor
First was easy to fix... not sure where the content for the second went...
Posted: Mon Oct 18, 2021 10:47 am
by parky
