Sunba 601 PTZ
Condor
Sunba 601 PTZ
Post by Condor » Fri Jun 09, 2017 6:34 am
Anyone have success with a Sunba 601 PTZ camera? I know the camera is working because I can control it using the web interface. ZoneMinder can talk to the camera but it cannot display the image in real time. Have ZoneMinder configured for RTSP. I can see images it has save to the hard drive, but nothing in the Monitor window.
jerrynavarete
Re: Sunba 601 PTZ
Post by jerrynavarete » Thu Jun 22, 2017 8:49 am
What kind of configuration did you do?
minviri
Re: Sunba 601 PTZ
Post by minviri » Sat Jan 13, 2018 4:36 am
Don't know if yall still need this info....
I was able to get my sunba 805 working with zoneminder.
Source Type: ffpmpeg
rtsp://admin:@x.x.x.x:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream
Reso: 1920x1080
PTZ:
Create a new control....
Type: Ffmpeg
Protocol: Netcat
Set Move, Pan, Tilt, Zoom, Focus, Iris to on
Control Address : x.x.x.x:8899
Auto Stop Timeout: 0.15 ##change this to set how far the pan/tilt moves
mikeng
Re: Sunba 601 PTZ
Post by mikeng » Sun Feb 25, 2018 12:19 am
@minviri I just bought the 405 version and was hoping to get the ptz to work with zoneminder. Can you elaborate on the PTZ part please? I looked under /usr/share/perl5/ZoneMinder/Control to add the perl script control file and the existing file is a lot more involved than what you had specified. Where did you set these and got PTZ to work. Sorry I am a new to this...thanks
mikeng
Re: Sunba 601 PTZ
Post by mikeng » Sun Feb 25, 2018 12:27 am
Ok nevermind, You have to enable OPT_CONTROL is checked in Options->System of ZM first. Then restart zoneminder. Then click on the source monitor before you see the "Control" tab. This is where you make your settings. Thanks
ScottishGeek
Re: Sunba 601 PTZ
Post by ScottishGeek » Fri Apr 26, 2019 2:00 pm
For the Sunba 405-D20X the following works:
Try either the Control Type as "ONVIF camera" or "Netcat ONVIF" to see if the following works. The "Netcat ONVIF" setting worked for me.
General
Name: {give the camera a name}
Source Type: ffmpeg
Function: {select an appropriate function from the dropdown}
Enabled: Tick
Maximum FPS: Empty
Alarm Maximum FPS: Empty
Source
Source Path: rtsp://{ip address}:554/user=admin&password={admin password}&channel=1&stream=0.sdp?
Remote Method: RTP/RTSP
Options: Empty
Target colorspace: 32 bit color
Capture Width: 1920
Capture Height: 1090
Control
Controllable: Tick
Control Type: Netcat ONVIF
Control Device: Empty
Control Address: {ip address}:8899
Auto Stop Timeout: 1.00
The most important thing is to use the correct RTSP stream, and for the Control type, use ONVIF with port 8899.
Users browsing this forum: GeorgeCostanza and 3 guests
