SV3C - Zoneminder (Help)
Kalabin
Post by Kalabin » Sat Apr 29, 2017 4:52 am
Need an assist here.
I have gone through the forums and seen other post's that guys are able to use this camera without any issues. I can view the camera via VLC @ the following address.
rtsp://192.168.1.113:554/11 (Source Stream)
rtsp://192.168.1.113:554/12 (Sub Stream)
However I have tried adding the camera as remote, ffmpeg etc and can not get it to pull a stream.
For Remote I am trying the following.
Remote Protocol : RTSP
Remote Method : RTP / RTSP
Remote Host Name : 192.168.1.113
Remote Host Port : 554
Remote Target Path : /11
* Tried this as /11, /12, 11, 12.
Re: SV3C - Zoneminder (Help)
Post by iconnor » Sat Apr 29, 2017 1:34 pm
Hard to say without logs. Look at them. Paste them here.
Maybe try the ONVIF detect method.
Maybe you need to add username/password?
Kalabin
Post by Kalabin » Sun Apr 30, 2017 6:16 pm
Thanks for the hint on the username / password.
The camera is setup to where they do not use a username / password. Looking through the forums I found someone with a similar issue where the following was enabled which would prevent the camera's feed from pulling.
Options > System > AUTH_RELAY
Changed this setting to "none" and poof the camera is working fine now.
Thanks for the nugget that got me looking in the right direction.
echilon
Post by echilon » Tue Oct 31, 2017 9:37 pm
Thanks so much!! I spent days banging my head against the wall over this exact problem. Made the change you suggested you found
Options > System > AUTH_RELAY set to none
And it started working. Thanks again to you and this Forum
