Searching for HD IR outdoor eyeball IP cameras
gregbzone
Post by gregbzone »
I'm searching for eyeball outdoor IR IP cameras for zoneminder recorder / server.
Prefer 3 megapixel or greater, and less than $150 per camera.
Running zoneminder 1.29 on Ubuntu on Intel NUC.
I found a few candidate cameras on Amazon - Has anyone successfully configured zoneminder to use any of these?
I'm looking for positive (or negative) responses.
None of these are specifically identified on the HW compatibility list.
  • Amcrest IP2M-844E 2 Megapixel 1080P POE Dome IP
    Amcrest IP3M-956E 3 Megapixel Dome IP
    Dahua IPC-HDBW5300 3 Megapixel Vari-Focal
    Dahua IPC-HDW1320S 3 Megapixel
    Dahua IPC-HDW4421M 4 Megapixel
    D-Link DCS-4802E Vigilance
    Grandstream GXV3610_FHD
    GrandStream GXV3610_HDv2
    GW Security GW5088IP 5 Megapixel
    GW Security GW5092IP 5 Megapixel
Other candidates welcome.
Thanks, Greg
river100
Re: Searching for HD IR outdoor eyeball IP cameras
Post by river100 »
Late to reply, just in case anyone else needs same info.
Most of those will work with Zoneminder.
I have a bunch of Dahuas and one Grandstream
working well on Zoneminder.
Only one I am not sure of is D-Link.
Look into onvif device manager
you can usually get the H264 string from it.
All but the grandstream are known for security issues, but in general should worok.
gregbzone
Post by gregbzone »
I picked a couple of Amcrest IP2M-844E cameras.
See Amcrest IP2M-844E setup notes here: viewtopic.php?t=25446
