Problem with PCi-E card combination of CX25853 and CX25821
p3k074
Post by p3k074 »
I have problem with start working Zoneminder with PCIE card with two chips onboard : CX25853 and CX25821. This is 8 channel dvr h264 pcie capture cards - made in china. I installed UBUNTU with all updates and Zoneminder. All fine Zoneminder start working but problem is no video from this card.
I think all looks fine but not work:
#lspci -vvvnn
04:00.0 Multimedia video controller [0400]: Conexant Systems, Inc. Device [14f1:8210]
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 3
        Region 0: Memory at fe400000 (64-bit, non-prefetchable) [size=2M]
        Capabilities: [40] Express (v1) Endpoint, MSI 00
                DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
                DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+
                        MaxPayload 128 bytes, MaxReadReq 128 bytes
                DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <2us, L1 <4us
                        ClockPM- Surprise- LLActRep- BwNot-
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk-
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
        Capabilities: [80] Power Management version 3
                Flags: PMEClk- DSI+ D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [90] Vital Product Data
                Unknown small resource type 00, will not decode more.
        Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
                Address: 0000000000000000  Data: 0000
        Capabilities: [100 v1] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
        Capabilities: [200 v1] Virtual Channel
                Caps:   LPEVC=1 RefClk=100ns PATEntryBits=1
                Arb:    Fixed+ WRR32+ WRR64+ WRR128-
                Ctrl:   ArbSelect=WRR64
                Status: InProgress-
                Port Arbitration Table [240] <?>
                VC0:    Caps:   PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
                        Arb:    Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
                        Ctrl:   Enable+ ID=0 ArbSelect=Fixed TC/VC=01
                        Status: NegoPending- InProgress-
                VC1:    Caps:   PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
                        Ctrl:   Enable- ID=1 ArbSelect=Fixed TC/VC=00
I do:
#modprobe -v cx25821
insmod /lib/modules/3.2.0-030200-generic/kernel/drivers/media/video/tveeprom.ko
insmod /lib/modules/3.2.0-030200-generic/kernel/drivers/media/video/btcx-risc.ko
insmod /lib/modules/3.2.0-030200-generic/kernel/drivers/media/video/videobuf-core.ko
insmod /lib/modules/3.2.0-030200-generic/kernel/drivers/media/video/videobuf-dma-sg.ko
insmod /lib/modules/3.2.0-030200-generic/kernel/drivers/media/video/videodev.ko
insmod /lib/modules/3.2.0-030200-generic/kernel/drivers/media/video/cx25821/cx25821.ko
#dmesg
[   87.844265] Linux video capture interface: v2.00
[   87.852787] cx25821: driver version 0.0.106 loaded
but nothing happen:
#ls -la /dev/video*
ls: cannot access /dev/video*: No such file or directory
I dont have any idea how do this card usable ... If any can help will be great ...
xmasin
Re: Problem with PCi-E card combination of CX25853 and CX258
Post by xmasin »
You have to recompile kernel module with this patch http://comments.gmane.org/gmane.linux.d ... ture/44985. Current kernel module doesn't have definition for generic card. I followed this guide for recompiling module http://wiki.centos.org/HowTos/BuildingKernelModules.
Regards
Radek Masin
marcin.gawenda
Post by marcin.gawenda »
Hi Radek,
How many video channels you get working? What exact card model you managed to work?
Regards,
Marcin
xmasin
Post by xmasin »
I get working all 8 video channels, in /dev/ you can see video0 - video11, but devices video8 - video11 are audio channels from decoder, so you can use only first 8 channels for Zoneminder. I have bought this card http://dx.com/p/8-ch-h-264-dvr-video-ca ... ntsc-42242.
Regards
Radek Masin
cctvsales
Post by cctvsales »
Radek Masin
Have you tested the cx25858 chip video card, use the ZM program?
Thank you
xmasin
Post by xmasin »
cctvsales wrote:Radek Masin
Thank you
unfortunatelly no, because I have only card with CX25853 and CX25821 chips.
Regards
Radek Masin
vadegdadeg
Re: Problem with PCi-E card combination of CX25853 and CX25821
Post by vadegdadeg »
Hello!
I have a similar problem. But the link to the patch is no longer available. Tell me at least what it was about, what keywords should I google for?
vadegdadeg
I figured out this problem!
My card contains:
CX25821-11Z
CX25853-12Z
Four sound ADC ES7240S
And two EEPROM's 24C02 and AT88SC0104CA this is "super-puper" Atmel CryptoMemory
At the beginning, I looked at the VID/PID of my card:
03:00.0 0400: 14f1:8210
        Subsystem: 5644:4e4c
        Flags: bus master, fast devsel, latency 0, IRQ 17
        Memory at f7c00000 (64-bit, non-prefetchable) [size=2M]
        Capabilities: [40] Express Endpoint, MSI 00
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [200] Virtual Channel
        Kernel driver in use: cx25821
        Kernel modules: cx25821
And if 14f1:8210 are standard, then subsystem is different from 'reference'...
By searching for the words 14f1:8210, I found these values ​​​​in the source.
I replaced 0000/0000 with my values ​​obtained from lspci.
File: cx25821-core.c
static const struct pci_device_id cx25821_pci_tbl[] = {
                /* CX25821 Athena */
                .vendor = 0x14f1,
                .device = 0x8210,
                .subvendor = 0x14f1,
                .subdevice = 0x0920,
                /* CX25821 No Brand */
                .vendor = 0x14f1,
                .device = 0x8210,
                .subvendor = 0x5644,
                .subdevice = 0x4e4c,
                /* --- end of list --- */
And it worked!
[    2.547701] cx25821: driver loaded
[    2.547757] cx25821 0000:03:00.0: enabling device (0100 -> 0102)
[    2.547870] cx25821: Athena Hardware device = 0x8210
[    2.547899] cx25821: cx25821[1]: subsystem: 5644:4e4c, board: CX25821 [card=1,autodetected]
[    2.853836] cx25821: Hardware revision = 0x00
[    2.853847] cx25821: cx25821[1]/0: found at 0000:03:00.0, rev: 0, irq: 17, latency: 0, mmio: 0xf7c00000
testbox cx25821 # ls -la /dev/vid*
crw-rw---- 1 root video 81, 0 мар  3 17:03 /dev/video0
crw-rw---- 1 root video 81, 1 мар  3 17:03 /dev/video1
crw-rw---- 1 root video 81, 2 мар  3 17:03 /dev/video2
crw-rw---- 1 root video 81, 3 мар  3 17:03 /dev/video3
crw-rw---- 1 root video 81, 4 мар  3 17:03 /dev/video4
crw-rw---- 1 root video 81, 5 мар  3 17:03 /dev/video5
crw-rw---- 1 root video 81, 6 мар  3 17:03 /dev/video6
crw-rw---- 1 root video 81, 7 мар  3 17:03 /dev/video7
testbox cx25821 # v4l2-ctl -d /dev/video1 --all
Driver Info:
        Driver name      : cx25821
        Card type        : CX25821
        Bus info         : PCIe:0000:03:00.0
        Driver version   : 5.15.82
        Capabilities     : 0x85200003
                Video Capture
                Video Output
                Read/Write
                Streaming
                Extended Pix Format
                Device Capabilities
        Device Caps      : 0x05200001
                Video Capture
                Read/Write
                Streaming
                Extended Pix Format
Priority: 2
Video input : 0 (Composite: ok)
Video Standard = 0x000000ff
        PAL-B/B1/G/H/I/D/D1/K
Format Video Capture:
        Width/Height      : 720/576
        Pixel Format      : 'YUYV' (YUYV 4:2:2)
        Field             : Interlaced
        Bytes per Line    : 1440
        Size Image        : 829440
        Colorspace        : SMPTE 170M
        Transfer Function : Default (maps to Rec. 709)
        YCbCr/HSV Encoding: Default (maps to ITU-R 601)
        Quantization      : Default (maps to Limited Range)
        Flags             :
Streaming Parameters Video Capture:
        Frames per second: 25.000 (25/1)
        Read buffers     : 2
User Controls
                     brightness 0x00980900 (int)    : min=0 max=10000 step=1 default=6200 value=6200 flags=slider
                       contrast 0x00980901 (int)    : min=0 max=10000 step=1 default=5000 value=5000 flags=slider
                     saturation 0x00980902 (int)    : min=0 max=10000 step=1 default=5000 value=5000 flags=slider
                            hue 0x00980903 (int)    : min=0 max=10000 step=1 default=5000 value=5000 flags=slider
But there was another problem, the sound does not work!
When cx25821-alsa is loaded, the module loads normally, a sound card appears in alsamixer, but without controls.
And if cx25821-alsa is unloaded and then mplayer is started, the system goes into kernel panic...
But I was warned that IDs should be:
It only works with boards with function 01 enabled. To check if your board supports, use lspci -n. If supported, you should see 14f1:8801 or 14f1:8811 PCI device.
I'll figure it out if the ADC board is soldered for nothing ...
My board
My board
vadegdadeg
Desoldered EEPROM, and reading it. The board didn't work without EEPROM, the 'subsystem' field disappeared.
You can see the identifier, circled in red, but I still didn’t understand about the first byte, a quote from the source (cx25821-alsa.c):
* PCI ID Table - 14f1:8801 and 14f1:8811 means function 1: Audio
* Only boards with eeprom and byte 1 at eeprom=1 have it
